Author Topic: corte cosso shocks  (Read 20765 times)
Offline crs-and-rms
  • heaven 23
corte cosso shocks
« on: September 11, 2007, 07:09:22 pm »
hi guys looking for info on some corte cosso shocks that ive come a cross any info would be good thanks :)
Re: corte cosso shocks
« Reply #1 on: September 11, 2007, 07:16:49 pm »
They dont work as good as the name sounds. grab a pair of something  better like koni or ohlins or well just about anything
« Reply #2 on: September 11, 2007, 07:32:11 pm »
Best info is just buy a set of YSS,because by the time you rebuild those C &C shocks you wll have spent 3/4 of the price and have a shock that is a 1/4 the performance as a set of YSS shocks.No compression,rebound,ride height or threaded preload.
Simple really ;D
« Last Edit: September 11, 2007, 07:35:21 pm by Lozza »
Offline crs-and-rms
  • heaven 23
« Reply #3 on: September 11, 2007, 11:06:16 pm »
well i got them free only want to find  seals and any info on them,i will be doing the work  i cant  afford new shocks
« Reply #4 on: September 11, 2007, 11:30:06 pm »
I have 2 Ohlins seal heads that I am sure will fit that I'm eager to part with ;D ;D ;D
Offline maicomc490t
« Reply #5 on: September 13, 2007, 08:16:24 pm »
Firko - where is Dave Cullen (radar) now as he could set everyone straight on the Ohlins conversion for Corte Cosse's - didn't he head north?
BULTACO M49 parts wanted
Maico31
« Reply #6 on: September 13, 2007, 08:54:23 pm »
Radar has a house here on the Gold Coast and was living here for a while but has moved back to Sydney and is running the Kawasaki road race team. He can rebuild your Corte Cosso's.
« Reply #7 on: September 13, 2007, 10:09:23 pm »
The Corte Cosso's on my MC490 worked OK but the springs sacked out really badly. I replaced the springs with a set from an RM400N/T and they worked much better. They were fairly decent after that.
Offline husky005
« Reply #8 on: September 14, 2007, 05:45:36 am »
Frank Pons at Biketek in Campbelltown will also do an Ohlins conversion on the Corte Cossos. I had him modify a set for a Husky 420 Auto a while ago and they worked great.
Paul
Offline crs-and-rms
  • heaven 23
« Reply #9 on: September 14, 2007, 05:59:16 pm »
thanks guys for all your help is the mod to put ohlins seal heads on them or is their more to it
« Last Edit: September 14, 2007, 07:17:29 pm by crs-and-rms »
Offline Husky500evo
« Reply #10 on: September 14, 2007, 09:37:46 pm »
I think that there is more to it than that . Corte Cossos use  11.5mm  shafts from memory , while Ohlins use 12mm .
Offline crs-and-rms
  • heaven 23
« Reply #11 on: September 15, 2007, 08:59:25 am »
ok . thanks they are 11.50
lms6201
« Reply #12 on: September 16, 2007, 07:18:27 am »
i have used the blue poly hydrolic ram seals , available at hydrolics suppliers , with excelent results , for uncommon sizes convert back to imperial , these have a better memory than the nitro ones , i have where necessary machined out the seal holder or sleived it down or whatever , i even have a set in some betor piggy backs with  pitted shafts and they are holding some pressure !!, nb, i haven,t got any gas in the ones i have done  , a good cheap cheap alternative i can buy over the counter for basic type shocks , on the list to try also and available in a simliar material is gas strut seals
Offline crs-and-rms
  • heaven 23
« Reply #13 on: September 22, 2007, 05:39:36 pm »
thanks guys for all you help will have to hold of on this as ive had a death in family :( and ive been stuck with all the  funeral costs you can pick your freinds but not your relatives  :)
YSS
« Reply #14 on: July 15, 2008, 06:06:46 pm »
From September on we have blank 12 mm hardened shafts(solid and hollow) and 12-36    and 12-30 sealblocks complet with DU bush and dirtscraper  to repair Ohlins , Koni , Corte Cosso, Bilstein  and of course YSS Shocks.
