Author Topic: Allround Fork springs  (Read 3464 times)
YSS
« on: December 03, 2008, 07:51:25 pm »
Due to constant pressure , I have now decided to construct and make a run of chrome silicon forksprings  for all 34 mm forks.  OD 26 mm and freelenght 480 mm. That would also cater to take the PD Forkvalve.
The rate I consider to make is 4.5N / mm  ,I  hope that would even cater for  the NSW tracks . Any thoughts , anyone interested.  ???
YSS
Re: Allround Fork springs
« Reply #1 on: December 03, 2008, 08:03:17 pm »
Brent can you check for the XT 500 ? I think they should fit perfect into them too.
gage
« Reply #2 on: December 03, 2008, 08:44:20 pm »
Hello,
Do you make any fork springs to suit a Honda CR125M? My manual doesn't have any specs for the wear limit on the springs - they are 509mm & 510mm respectively, so I'm not sure if they're past their use by date.
Regards, Ron
YSS
« Reply #3 on: December 03, 2008, 09:06:40 pm »
Whats the OD of your springs?
Offline brent j
« Reply #4 on: December 03, 2008, 09:09:30 pm »
Walter,
I have both straight and offset axle XT forks here and a day off on Friday so I'll check both and let you know.
Both XT and TT use 36mm forks but the smaller OD springs will fit
I think that rate will be fine for an XT/TT,
Brent
« Last Edit: December 03, 2008, 09:16:15 pm by brent j »
YSS
« Reply #5 on: December 03, 2008, 09:14:43 pm »
If we make OD 24  26 and 28  that should cover many models. The rest we can make up with preload spacers , I think .
gage
« Reply #6 on: December 03, 2008, 09:21:27 pm »
The CR125M springs are 22.50 mm O.D. and the tube is 25.00mm inside diameter
YSS
« Reply #7 on: December 03, 2008, 09:37:17 pm »
Dont get fooled by the thread , measure  at least 50 mm down the tube .
« Reply #8 on: December 03, 2008, 09:38:02 pm »
Hey Mr YSS you make an all square fork spring? Some of those old Eastern block countries most likely used um....
YSS
« Reply #9 on: December 03, 2008, 09:43:48 pm »
How many do you need Tim ? Remember the corner will be be the weakest point  ;D
« Reply #10 on: December 03, 2008, 10:09:07 pm »
The $$ ???
« Reply #11 on: December 03, 2008, 10:13:28 pm »
I'm interested! 4.5N/mm - suitable for a semi-fat, semi-slow bloke like me?
Discount for bulk buy?  ;)
YSS
« Reply #12 on: December 03, 2008, 10:16:43 pm »
Yes there will be bulk possible buying . But Les and Fernando will be in the box seat  unless  your numbers are 2 digits  ;)
