Clubroom
Tech Talk
Where can buy jet reamers 2.0mm to 3.0mm?
Topic: Where can buy jet reamers 2.0mm to 3.0mm? (Read 20221 times)
John Orchard
^^^ July 1984
April 30, 2023, 04:51:11 pm »
Anyone know where I can buy tapered jet reamers, maybe a set of 5 or 6 that range between from 2.00mm to 3.00mm (yes to open needle-jets :-) ), style as per the ones in this link:
https://www.misterworker.com/en/kukko/nozzle-reamers-set-12-pcs/59063.html?gmc_currency=8&SubmitCountry=AU&gclid=Cj0KCQjwgLOiBhC7ARIsAIeetVAJy33u6HZdY3VViFi2whChlZCXy1f5LJhZY4fv_kYDTA_Fm-fYAbcaAnJ7EALw_wcB
But up to 3.00mm, or maybe 2.80mm
John Orchard
^^^ July 1984
Re: Where can buy jet reamers 2.0mm to 3.0mm?
April 30, 2023, 05:10:24 pm »
What do you think of these?
https://www.tracytools.com/product/taper-pin-reamers-set-hss-1-16-1-4/
$109 delivered.
Last Edit: April 30, 2023, 05:17:04 pm by John Orchard
pmc57
A-Grade
May 01, 2023, 07:22:45 pm »
Try Capital Cutting Tools in Hamilton Victoria (Email:
[email protected]
), they have Chucking reamers up from 2.0mm (H7) in 0.1mm increments for about $22 ea + GST. They may even do more specific sizes if you ask ie 0.05 increments.
sleepy
May 02, 2023, 04:42:01 pm »
I use drills. I have 0.3mm to 2.5mm in .05mm steps and bigger sizes in "Number" drills. Number drill sizes
https://littlemachineshop.com/reference/numberdrillsize.php
I like the drills as they are a fixed size where the tapered reamers will open things out but difficult to control the size.
The mm sizes match Mikuni pilot jets as they are in mm's, meaning a #35 pilot is .35mm etc. Main jet are more difficult as they are in flow rate but most of the jet drilling I do is for Methanol so the .05mm steps are more than close enough.
Momus
May 02, 2023, 10:31:43 pm »
Ya, twist drill go up to 5.00 mm in .05 mm (0.002") increments and brass is the easiest material.
If you love it, lube it.
Clubroom
Tech Talk
