Author Topic: Where can buy jet reamers 2.0mm to 3.0mm?  (Read 20193 times)
« on: April 30, 2023, 04:51:11 pm »
Anyone know where I can buy tapered jet reamers, maybe a set of 5 or 6 that range between from 2.00mm to 3.00mm (yes to open needle-jets :-) ), style as per the ones in this link:  https://www.misterworker.com/en/kukko/nozzle-reamers-set-12-pcs/59063.html?gmc_currency=8&SubmitCountry=AU&gclid=Cj0KCQjwgLOiBhC7ARIsAIeetVAJy33u6HZdY3VViFi2whChlZCXy1f5LJhZY4fv_kYDTA_Fm-fYAbcaAnJ7EALw_wcB  But up to 3.00mm, or maybe 2.80mm
Re: Where can buy jet reamers 2.0mm to 3.0mm?
« Reply #1 on: April 30, 2023, 05:10:24 pm »
« Last Edit: April 30, 2023, 05:17:04 pm by John Orchard »
Offline pmc57
« Reply #2 on: May 01, 2023, 07:22:45 pm »
Try Capital Cutting Tools in Hamilton Victoria (Email: [email protected]), they have Chucking reamers up from 2.0mm (H7) in 0.1mm increments for about $22 ea + GST. They may even do more specific sizes if you ask ie 0.05 increments.
Offline sleepy
« Reply #3 on: May 02, 2023, 04:42:01 pm »
I use drills. I have 0.3mm to 2.5mm in .05mm steps and bigger sizes in "Number" drills. Number drill sizes https://littlemachineshop.com/reference/numberdrillsize.php
I like the drills as they are a fixed size where the tapered reamers will open things out but difficult to control the size.
The mm sizes match Mikuni pilot jets as they are in mm's, meaning a #35 pilot is .35mm etc. Main jet are more difficult as they are in flow rate but most of the jet drilling I do is for Methanol so the .05mm steps are more than close enough.
Offline Momus
« Reply #4 on: May 02, 2023, 10:31:43 pm »
Ya, twist drill go up to 5.00 mm in .05 mm (0.002") increments and brass is the easiest material.
If you love it, lube it.
