Author Topic: rattle can black frame paint  (Read 37248 times)
« on: December 25, 2021, 01:02:33 am »
doing a Doc style resto on my ts185k and what brand of rattle can black matches up to what suzuki used in 1973?as the tin i got from repco is just tooo black
Re: rattle can black frame paint
« Reply #1 on: December 25, 2021, 01:01:57 pm »
I use Septone Acrylic Satin black and a super light mist of clear, it has a bit more grey than the Export brand Gloss Enamel.
Offline Nebo
« Reply #2 on: December 26, 2021, 11:53:38 am »
Other suzuki owners may know a the correct black for the TS frame. Can recall that some suzuki oem frames were painted in a semi gloss paint. With bright light looked a little grey. I think a close match was made by VHT.
Friend used Killrust epoxy Enamel on his TM and RM frames with good results.
Have used Rust-Oleum Black Epoxy on my Maico Square Barrel Frame and Koni with shocks with good results.
But this a true Gloss black.
 Dulux and White knight are good spray can paints but are a bit thin and the paint can easy run.
Offline huskibul
« Reply #3 on: December 28, 2021, 05:52:07 pm »
Hey matt in recent years ive been using on frames dupli-color (engine enamel with ceramic) -DE1635 Ford semi gloss black ,from repco etc good match for vintage stuff not too glossy ,fuel & oil resistant,bigger 340g cans -cheers
Offline Nebo
« Reply #4 on: December 28, 2021, 06:03:55 pm »
 This would be good for my Ford Brake disc splash guards.
  And its on special at Repco. $12.80. $3.20 off.
Offline huskibul
« Reply #5 on: December 28, 2021, 06:51:00 pm »
 Yeah its not bad stuff nebo ,we use it on bikes ,4x4 bars/racks etc not glossy which is good too ????
Offline Slow Pete
« Reply #6 on: December 30, 2021, 06:15:15 pm »
Once you decide on the coulor try the paint place, they can supply 2 pack paint in a rattle can.   About $50
Pete
Past owner of.  Bultaco 125,  Suzuki RM250A, RM125C, RM125T, RM400N, RM125X, Maico AW250 1977.   Presently 81 RM250X , 87 RM125H , 86 RM250G & 81 RM125X.   Current projects 80 RM400T & 78 RM125C
Offline huskibul
« Reply #7 on: January 01, 2022, 06:08:03 pm »
Yeah the 2pak cans are great -especially for tanks etc -bit more prep tho
