Marque Remarks
Suzuki
rattle can black frame paint
Topic: rattle can black frame paint (Read 35664 times)
TT5 Matt
December 25, 2021, 01:02:33 am »
doing a Doc style resto on my ts185k and what brand of rattle can black matches up to what suzuki used in 1973?as the tin i got from repco is just tooo black
pokey
Arse .. Elbow. Know the difference
Re: rattle can black frame paint
December 25, 2021, 01:01:57 pm »
I use Septone Acrylic Satin black and a super light mist of clear, it has a bit more grey than the Export brand Gloss Enamel.
Nebo
C-Grade
December 26, 2021, 11:53:38 am »
Other suzuki owners may know a the correct black for the TS frame. Can recall that some suzuki oem frames were painted in a semi gloss paint. With bright light looked a little grey. I think a close match was made by VHT.
Friend used Killrust epoxy Enamel on his TM and RM frames with good results.
Have used Rust-Oleum Black Epoxy on my Maico Square Barrel Frame and Koni with shocks with good results.
But this a true Gloss black.
Dulux and White knight are good spray can paints but are a bit thin and the paint can easy run.
huskibul
December 28, 2021, 05:52:07 pm »
Hey matt in recent years ive been using on frames dupli-color (engine enamel with ceramic) -DE1635 Ford semi gloss black ,from repco etc good match for vintage stuff not too glossy ,fuel & oil resistant,bigger 340g cans -cheers
Nebo
C-Grade
Reply #4 on:
December 28, 2021, 06:03:55 pm »
This would be good for my Ford Brake disc splash guards.
And its on special at Repco. $12.80. $3.20 off.
huskibul
Reply #5 on:
December 28, 2021, 06:51:00 pm »
Yeah its not bad stuff nebo ,we use it on bikes ,4x4 bars/racks etc not glossy which is good too
Slow Pete
C-Grade
Reply #6 on:
December 30, 2021, 06:15:15 pm »
Once you decide on the coulor try the paint place, they can supply 2 pack paint in a rattle can. About $50
Pete
Past owner of. Bultaco 125, Suzuki RM250A, RM125C, RM125T, RM400N, RM125X, Maico AW250 1977. Presently 81 RM250X , 87 RM125H , 86 RM250G & 81 RM125X. Current projects 80 RM400T & 78 RM125C
huskibul
Reply #7 on:
January 01, 2022, 06:08:03 pm »
Yeah the 2pak cans are great -especially for tanks etc -bit more prep tho
Marque Remarks
Suzuki
