Author Topic: Front number plate mounting  (Read 111755 times)
Offline craigclayton
« on: August 01, 2021, 12:09:12 pm »
I need to mount a new number plate to the Ktm but need a bracket or brackets of some sort to fix to the 38 mm forks and then to the back of the number plate. Have found some nice CNC machined one in USA but will cost a bit to post over. Have spent a bit of time on partzilla looking through various makes and models but not found any yet.can anybody remember or think of a bike that would have used something like this, don’t want to just zip tie through the plate and around the forks.
Cheers C
74 Bultaco 250, 77 RM125b
Offline PeterC
  • Bultaco MK 11
Re: Front number plate mounting
« Reply #1 on: August 01, 2021, 02:09:19 pm »
I recently got some to suit 35mm , but like you am searching for 38mm for another project. There are available rubber ones for the bultacos 35 mm don't know if would work with 38 mm
Thumbs Up!
« Reply #2 on: August 01, 2021, 02:17:27 pm »
 Take a trip to your local plumbing supplies or hydraulics supplies like Reese and talk to them about pipe saddles  and saddle clamps. The choices are massive. Rubber lined SS or nylon blocks for a cleaner look.
Offline PeterC
  • Bultaco MK 11
« Reply #3 on: August 01, 2021, 05:54:02 pm »
The hydraulic ones come in 35 mm
Preston pretty have a range of sizes at covid tax pricing
Thumbs Up!
Offline Canam370
« Reply #4 on: August 01, 2021, 09:16:35 pm »
Try 'P' clamps. Enzed had them.
« Reply #5 on: August 02, 2021, 07:32:09 am »
Go to a hardware store (Bunnings etc) & buy some "tool clips", they are spring clips designed to hold shovel/rakes etc. screw or rivet them to the front plate, then use an o'ring on the back of them. They work & look a treat.
« Reply #6 on: August 02, 2021, 08:28:19 pm »
Thank you all for the suggestions, will follow up.
Cheers C
« Reply #7 on: August 03, 2021, 06:59:39 pm »
good Idea K Man
