Author Topic: VM38 one float higher!  (Read 9440 times)
« on: October 19, 2018, 04:02:23 pm »
What am I not considering? The floats on my OEM Kawa VM38 live in the bowl and slide up & down on posts fastened to the bottom of the fuel bowl.
With bowl off the carb body, I filled the bowl with fuel, I wanted to take a measurement of where the lift-pins sit, that lift the arms that close the needle & seat, when the bowl is full of fuel.
One float sits about 3mm higher than the other, there is no liquid in the float, they are both the same size, they both have about 1.5mm clearance from the side-wall of the bowl.
I wonder if the uneven lift pressure on the needle & seat closing arms would effect smooth needle operation?
Ideas?  :-)
Offline bazza
Re: VM38 one float higher!
« Reply #1 on: October 20, 2018, 09:51:25 am »
One of the posts bowl slides on not bent?
« Reply #2 on: October 20, 2018, 11:01:48 am »
Nope, not bent. l wonder if a different internal air pressure? Or the plastic is thicker in one?
l have another old carb here, l checked the floats in it; equal, l'll run with it :-)
« Reply #3 on: October 20, 2018, 12:21:48 pm »
helium in one float, air in the other? set up for short circuit??  ;D ;D
Offline Curtis
    • japspec.com.au
« Reply #4 on: October 22, 2018, 10:18:48 am »
Try weighing the floats?
« Reply #5 on: October 22, 2018, 08:25:59 pm »
Good point :-)
« Reply #6 on: October 23, 2018, 04:42:09 pm »
common on J O ...what is outcome  ;D
« Reply #7 on: October 23, 2018, 06:38:55 pm »
bathroom scales allready maxed out ;D ;D
Offline fred99999au
« Reply #8 on: October 23, 2018, 07:27:19 pm »
Funny, I have a mate with this affliction. Apparently one is atrophied. Still made two kids though
« Reply #9 on: October 23, 2018, 08:45:24 pm »
Have not followed it up, I just switched to a pair that are equal  :-)
