Author Topic: what do these belong to???  (Read 12947 times)
Offline jimson
  • Sanctuary point N.S.W
« on: September 07, 2008, 06:07:20 pm »
i've got a pair of forks here don't know what they are off i'll put some pictures up and see what you experts have got to offer  :-\  the top is 34mm and the fork shaft is 36 mm
« Last Edit: September 07, 2008, 06:16:45 pm by jimson »
Offline crs-and-rms
  • heaven 23
Re: what do these belong to???
« Reply #1 on: September 07, 2008, 06:56:18 pm »
rm a 125 maybe what you doing with them
Offline pmc57
« Reply #2 on: September 07, 2008, 08:46:01 pm »
Interesting!! The banjo bolts in the top tells me they may have had a pressure equaliser type modification performed, the bottoms look like Suzuki but than again they could be Yamaha, Honda or Kawasaki. My best guess is.... Yamaha mid 70's, oh it's all too hard..
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #3 on: September 07, 2008, 09:10:15 pm »
i don't think they're yamaha.
i don't recall any models having the oil drain at the front of the fork leg, most were on the side and the brake plate lug & dust seals don't look yamaha to me either. or the top of the staunchions.
colours right though... ;D
but hey, ive been wrong before...
"flat bickie"
TM BILL
« Reply #4 on: September 07, 2008, 09:11:03 pm »
74 ,75, 76 KX 250 But the brake stay doesn't look right  ???
« Last Edit: September 07, 2008, 09:12:48 pm by TM BILL »
Offline pmc57
« Reply #5 on: September 07, 2008, 09:26:47 pm »
Hey TM, how's the leg?
Doc
« Reply #6 on: September 08, 2008, 06:13:48 am »
Jimson, they look like early XT500 forks to me  ;)
TM BILL
« Reply #7 on: September 08, 2008, 10:51:22 am »
Gidday peter  :) its coming along thanks mate  ;) i put a bit of an update on the original thread  :)
Offline jimson
« Reply #8 on: September 08, 2008, 08:40:03 pm »
I don't think there yamaha the allan key in the bottom is a different size than the other yammie forks I have  :-\
Offline JC
« Reply #9 on: September 09, 2008, 12:54:44 pm »
Jimson
I tho't these maybe mid70s KX, but they're not 75/76. They had the oildrain screws on the outside of the leg, not behind as above. They maybe 74KX which were diff. I tho't both had axle dia of about 17mm (for sleeved nuts) on both sliders. I also tho't both KX models had diff-looking castings at the axle than shown in the pics above. The ones above look more Yam-ish to me.
My hunch would be XT/TT500 as Doc says, but I don't know if they were 34mm at the top. I do know the Yam tubes were distinctive at the bottom (inside the sliders) if you feel like pulling one apart & posting a pic.
I'm
Offline JC
« Reply #10 on: September 09, 2008, 04:17:44 pm »
Hmmm,
They don't appear to be TT500 forks from the pics I checked.  ???
Doc
« Reply #11 on: September 10, 2008, 12:04:24 pm »
John I have no idea what size the XT forks are, I was thinking they were from the first '76 model. The taper at the top had me thinking this but I think the later models had slightly different forks as they had fork boots fitted stock. I didn't think the taper went quite so far down the staunchion so I really don't know, they aren't Suzuki though ;) Axle size may give another clue :-\ where you been shopping to find such critters Jimson??
Offline vandy010
« Reply #12 on: September 10, 2008, 01:55:12 pm »
i don't think they're XT or TT forks.
early 76 model XT/TT were 36mm with no taper at the top and the brake lug was more chunky than in these pics.
interesting but...
so you could probably use a YZ125x {36mm} bottom clamp with any early DT/YZ/MX {34mm} top clamp.
the XT clamps are wider than the DT/YZ/MX so it wouldn't work with them.
or just post them to Vandy... ;D
« Last Edit: September 10, 2008, 01:57:58 pm by vandy010 »
"flat bickie"
Offline JC
« Reply #13 on: September 10, 2008, 03:20:40 pm »
Yes, as far as I could tell, early XT/TT500 forks were 36mm to the top; later ones seem to be reduced dia between the triples, but 36dia again at the top.  Ones I looked at were also diff to the pics above at the boss where the axle attaches.
« Reply #14 on: September 10, 2008, 06:04:55 pm »
i agree, they are not any XT or TT 500
