Author Topic: what do these belong to???  (Read 12952 times)
Re: what do these belong to???
« Reply #15 on: September 10, 2008, 06:40:05 pm »
How about Can Am? I know these are not off a 79 or 80 model but Can Am used an air fork set up like this with banjo bolts.  Maybe they are from a mid 70’s Can Am as the later ones i have pictures of are for the leading axle forks and they have the banjo bolts in the caps.
« Reply #16 on: September 10, 2008, 07:04:13 pm »
Can-Am used Betor and then Marzocci forks and these are definitely not from either of those factories. My guess is that they're from a Yamaha but I'm not putting my house on it.
YSS
« Reply #17 on: September 10, 2008, 07:25:41 pm »
Dont put your house on that Mark . I remember doing a pair like this and I think they where english.
Offline jimson
  • Sanctuary point N.S.W
« Reply #18 on: September 10, 2008, 07:47:44 pm »
This is good I've had these forks for about 4 months hoping they where pr75 and usable I'll clean them up on Saturday and take another pic. If they are english Walter what brand and year are they  :) jimson
YSS
« Reply #19 on: September 10, 2008, 07:59:30 pm »
Thats a few moons ago , I did them . I remember them because it was hard to blend in the chroming .
I think they where of a Norton. I will try to look it up when I get back to Australia.
Offline jimson
« Reply #20 on: September 10, 2008, 08:05:16 pm »
Thanks Walter  ;D you never know you might have another pair to rebuild.jimson
Maico31
« Reply #21 on: September 10, 2008, 08:09:11 pm »
I reckon they're kayaba forks from a jap bike. They are very similar to my RH250 forks.
« Reply #22 on: September 10, 2008, 08:18:09 pm »
the Can Am forks i have seen with banjo bolts in the top caps like these ones were marzocchis but leading axles
Offline JC
« Reply #23 on: September 11, 2008, 08:09:59 am »
I think I could categorically say they are not canam & not english. Can am ran only 35mm forks in straight lforks (axle on bottom of slider). Likewise the english. Canam never ran 36mm forks & I'd be nearly as certain about the british.
Seems to me theres little/no doubt they are Jap; kayaba not showa (again, I'm fairly sure honda/showa never ran 36mm forks)
« Reply #24 on: September 11, 2008, 09:07:26 am »
An interesting riddle :).
I've seen forks 'waisted' between the triples but never the top section a different dia. Strange engineering me thinks, for a weight savings of..... ??? ::) Are you sure both the mechining and the banjo's are not home modifications.
Is the visiable marks at the change in dia where the lower triples clamped?
Offline JC
« Reply #25 on: September 11, 2008, 10:43:48 am »
G,
Its not uncommon on Jap forks. I think it simply for ease of removal.
Doc
« Reply #26 on: September 11, 2008, 05:09:07 pm »
okies, not XT then how 'bout Hodaka 250 Thunderpooch?  :-\  Darcy, are you lurking? can you give us a ya or nay on the Hoddy? ;)
« Last Edit: September 11, 2008, 05:11:00 pm by Doc »
Offline JC
« Reply #27 on: September 11, 2008, 06:40:24 pm »
Doc,
I think they were 34mm forks not 36mm
Offline facthunt
« Reply #28 on: September 21, 2008, 01:14:41 am »
Early KX?
