Author Topic: Pe stator.  (Read 8201 times)
Offline Glen08
Pe stator.
« on: June 22, 2017, 10:30:35 am »
Hi all.
I have a 1980 pe175 stator flywheel etc & plan to put in on my 250.. The 175 pulse coil is shot..
Q- before I buy one from eBay is there any other Suzie model that will go in..ts er..??
Thanks guys.
Offline Glen08
Re: Pe stator.
« Reply #1 on: June 22, 2017, 11:10:35 am »
I've done a search with no real luck..part numbers don't match so it's a lucky dip question  :)
Re: Pe stator.
« Reply #2 on: June 22, 2017, 12:59:27 pm »
Pretty sure the TS coils have wider spaced coil mounting holes because the flywheels are a larger diameter. I know the lighting coils are longer so i would expect the ignition ones to be too.
Offline Glen08
Re: Pe stator.
« Reply #3 on: June 22, 2017, 02:21:18 pm »
Thanks.
A mate has offered a new pulse coil he had stashed thankfully.
Offline matcho mick
    • Moto Tumbi
Re: Pe stator.
« Reply #4 on: June 22, 2017, 02:40:28 pm »
IT175's pulse is 12.4,the 2fiddys only 7.5,dont suppose makes a difference?,bit worried about my 90 YZ250 pulse coil it reads 148.4??,where i've hooked it up to my 80 IT175 black box,could be tricky??, :P
Offline Glen08
Re: Pe stator.
« Reply #5 on: June 22, 2017, 03:30:27 pm »
I have a 80/81 it175 motor doing nothing.
Sure it's all there too.
Offline matcho mick
    • Moto Tumbi
Re: Pe stator.
« Reply #6 on: June 22, 2017, 06:39:31 pm »
so have i  :),i need centre port in my YZ100K,looked at johnny Z's 82 IT175 om the weekend,it is my YZ frame main frame with longer alloys/arm,it has the centreport motor i need!, :P
Offline Glen08
Re: Pe stator.
« Reply #7 on: July 03, 2017, 11:06:33 am »
Done some research & tf125 has same part number as 81/82 pe175..
Tf125 - primary - 32140-39160
Tf125 - pulse - 32150-40520
Anyone confirm in real time..?
Offline Glen08
Re: Pe stator.
« Reply #8 on: July 03, 2017, 12:50:55 pm »
And it seems Milk hone Suzuki has the coils...laughing..!
