Clubroom
Tech Talk
Pe stator.
Topic: Pe stator. (Read 8199 times)
Glen08
B-Grade
Pe stator.
June 22, 2017, 10:30:35 am »
Hi all.
I have a 1980 pe175 stator flywheel etc & plan to put in on my 250.. The 175 pulse coil is shot..
Q- before I buy one from eBay is there any other Suzie model that will go in..ts er..??
Thanks guys.
Glen08
B-Grade
Re: Pe stator.
June 22, 2017, 11:10:35 am »
I've done a search with no real luck..part numbers don't match so it's a lucky dip question
LWC82PE
Superstar
Re: Pe stator.
June 22, 2017, 12:59:27 pm »
Pretty sure the TS coils have wider spaced coil mounting holes because the flywheels are a larger diameter. I know the lighting coils are longer so i would expect the ignition ones to be too.
Glen08
B-Grade
Re: Pe stator.
June 22, 2017, 02:21:18 pm »
Thanks.
A mate has offered a new pulse coil he had stashed thankfully.
matcho mick
Re: Pe stator.
Reply #4 on:
June 22, 2017, 02:40:28 pm »
IT175's pulse is 12.4,the 2fiddys only 7.5,dont suppose makes a difference?,bit worried about my 90 YZ250 pulse coil it reads 148.4??,where i've hooked it up to my 80 IT175 black box,could be tricky??,
Glen08
B-Grade
Re: Pe stator.
Reply #5 on:
June 22, 2017, 03:30:27 pm »
I have a 80/81 it175 motor doing nothing.
Sure it's all there too.
matcho mick
Re: Pe stator.
Reply #6 on:
June 22, 2017, 06:39:31 pm »
so have i
,i need centre port in my YZ100K,looked at johnny Z's 82 IT175 om the weekend,it is my YZ frame main frame with longer alloys/arm,it has the centreport motor i need!,
Glen08
B-Grade
Re: Pe stator.
Reply #7 on:
July 03, 2017, 11:06:33 am »
Done some research & tf125 has same part number as 81/82 pe175..
Tf125 - primary - 32140-39160
Tf125 - pulse - 32150-40520
Anyone confirm in real time..?
Glen08
B-Grade
Re: Pe stator.
Reply #8 on:
July 03, 2017, 12:50:55 pm »
And it seems Milk hone Suzuki has the coils...laughing..!
Clubroom
Tech Talk
Pe stator.
