Clubroom
Tech Talk
Triumph 750 twin
Topic: Triumph 750 twin (Read 6842 times)
jimson
Sanctuary point N.S.W
Triumph 750 twin
June 08, 2017, 06:19:09 pm »
G'day viewers, my kickstarter lever has no return. So my question is. Is it a difficult job to fix, the return spring ? Basic skill level or comanding a space ship kinda thing ? Jimson
GD66
Re: Triumph 750 twin
June 08, 2017, 06:26:51 pm »
This might be worth a look, keep the safety glasses at hand before you mount her up tho !
https://www.youtube.com/watch?v=Lchh-pQP9Ss
LWC82PE
Superstar
June 08, 2017, 06:47:56 pm »
Not difficult. Just take off the gear box outer cover and you will see it right there. Make note of what spline the spring is hooked into on the kickstart shaft.
Service manual will be a help to have too.
matcho mick
June 08, 2017, 10:36:29 pm »
prob too late
,but engage the k/starter 10.30-11am posi. then remove outer cover & k/s lever as a whole assembly,then u look at where spring engages or where its broken?,
ps Leigh is correct,k/start lever preload is determined on the quadrant s shaf'ts teeth
jimson
June 09, 2017, 04:34:25 pm »
Thanks for your guidance everyone, I'll let you know how it goes, when I get to it. Jimson
matcho mick
June 09, 2017, 09:59:18 pm »
justa thought,leave the gear lever on too Garry,use that for leverage wiggling the cover off when you get toit,
err
it is on the right (earlyT140??),if later ignore this bit
Clubroom
Tech Talk
Triumph 750 twin
