Author Topic: Triumph 750 twin  (Read 6839 times)
Offline jimson
  • Sanctuary point N.S.W
Triumph 750 twin
« on: June 08, 2017, 06:19:09 pm »
G'day viewers, my kickstarter lever has no return. So my question is. Is it a difficult job to fix, the return spring ? Basic skill level or comanding a space ship kinda thing ? Jimson
Offline GD66
Re: Triumph 750 twin
« Reply #1 on: June 08, 2017, 06:26:51 pm »
This might be worth a look, keep the safety glasses at hand before you mount her up tho !  8)
https://www.youtube.com/watch?v=Lchh-pQP9Ss
« Reply #2 on: June 08, 2017, 06:47:56 pm »
Not difficult. Just take off the gear box outer cover and you will see it right there. Make note of what spline the spring is hooked into on the kickstart shaft.
Service manual will be a help to have too.
Offline matcho mick
    • Moto Tumbi
« Reply #3 on: June 08, 2017, 10:36:29 pm »
prob too late  ::),but engage the k/starter 10.30-11am posi. then remove outer cover & k/s lever as a whole assembly,then u look at where spring engages or where its broken?, :P
ps  Leigh is correct,k/start lever preload  is determined on the quadrant s shaf'ts teeth
Offline jimson
« Reply #4 on: June 09, 2017, 04:34:25 pm »
Thanks for your guidance everyone, I'll let you know how it goes, when I get to it. Jimson
Offline matcho mick
    • Moto Tumbi
« Reply #5 on: June 09, 2017, 09:59:18 pm »
justa thought,leave the gear lever on too Garry,use that for leverage wiggling the cover off when you get toit, :P
err  ::) it is on the right (earlyT140??),if later ignore this bit
