Author Topic: 84 XR500 Engine into a 84 CR500???  (Read 12391 times)
Offline mic
« on: June 04, 2017, 10:33:15 am »
Have a spare xr and can get a cr without an engine.
You guys rekon it doable, any advise?
« Last Edit: June 04, 2017, 10:41:04 am by mic »
-toe -
74 XR75 - 75 CR125M1 - 84 XR500 x 2 - 79 CR250 x 2
Re: 84 XR500 Engine into a 84 CR500???
« Reply #1 on: June 04, 2017, 06:34:47 pm »
You guys reckon it doable, any advise?
would depend if the cradle on the CR is deep enough and accepting enough for the deeper sump of the XR donk,,,remember it just wont work unless you get the counter sprocket shaft center in the same position as the CR one,,,,or a move in the exact right direction......
Might be a better option to gut the XR of unacceptable weight items Mic
eg;
alloy tank,,,
honkass muffler heavier than a mud filled barge,,,,
Steel swing arm,,,,
Say if you were motocrossing?     there is lots of unnecessary weight that you can cull from a XR500
I love their torque,,,short shift into chain lug and flatten them into a high revs,,,oh what a feeling  :)
« Reply #2 on: June 04, 2017, 07:57:48 pm »
Want to sell the rolling chassis?
« Reply #3 on: June 04, 2017, 08:01:32 pm »
And with the xr donk being dry sump there's a need to rig up a big enough oil tank as well,then make a airbox for the twin carb setup on those motorswhy not try to put the good cr suspension on your xr frame and save the head fork
« Reply #4 on: June 04, 2017, 10:25:47 pm »
That's the go ,,,, less head forks,,,
Offline mic
« Reply #5 on: June 05, 2017, 05:36:57 pm »
hmmm, forgot about the dry sump....
-toe -
Offline mic
« Reply #6 on: June 05, 2017, 05:40:29 pm »
nar, its spares for my one i bought brand new when i was 25.
owned it for about 8 years, tracked it down last year and found it in rocky, now registered and still a weapon....
-toe -
