Author Topic: Maico 326 revisited  (Read 22544 times)
Offline JC
Re: Maico 326 revisited
« Reply #30 on: October 28, 2008, 12:32:45 pm »
Paul,
I'd be very interested to know the width & depth of the inlet port if you have a 326 barrell there.
Offline paul
« Reply #31 on: October 28, 2008, 02:34:59 pm »
not here  yet
Offline JC
« Reply #32 on: November 14, 2008, 05:52:40 pm »
Looks to me like std 250 cylinder Paul. Is it 67mm bore?
Offline paul
« Reply #33 on: November 14, 2008, 06:02:36 pm »
yep so then its not what i was told ,sorry  i carnt help cause that what i was led to belive when it was sent ,the mystery continues
Offline JC
« Reply #34 on: November 14, 2008, 06:15:07 pm »
Paul,
It maybe the 'Stacker-modified 250'. It supposedly used a Magnum piston & had some machining done to the barrell/head.
Is the top of the ring 2-3mm down from the top edge of the piston? (Magnum pistons were)
Also an you measure the ht of the barrell from base-gasket surface to top of liner?
(I ask this cos it may have been machined so as to 'drop' the barrell & retard Ex/Tr timing. This should identify if anything 'trick' has been done to it)
Offline paul
« Reply #35 on: November 14, 2008, 06:36:20 pm »
from the base gasket to the top of the liner is 133 mm
the head has notches in the top were it was held in a lathe and the piston ring is at the top /l shaped ring
Offline paul
« Reply #36 on: November 14, 2008, 06:41:11 pm »
Offline JC
« Reply #37 on: November 14, 2008, 06:53:09 pm »
Hmm, thats std ht for the barrell. I'd say he just milled the head (by the look of the pics) to raise Comp Ratio. Piston appears to be regular 250 piston.
Offline JC
« Reply #38 on: November 15, 2008, 09:52:48 am »
P,
Can you check the deck ht of the piston pls - top of gudgeon to top of ring.
Also, does it have round hole or oblong hole in the back of the piston for the boost port?
