Marketplace
Wanted
Ohlins internal bits.
Topic: Ohlins internal bits. (Read 7333 times)
hampster
B-Grade
January 23, 2017, 11:42:57 am »
Hi All,
After pistons for remote reservoir Ohlins off a 1980 WR Husky, or a set of shocks that can be rebuilt.
Thanks Chris.
bigk
Kangaroo Flat Victoria
Re: Ohlins internal bits.
January 23, 2017, 12:54:09 pm »
New parts readily available from local Aus supplier. You'll have to go through a bike shop though, doubt they'll sell to you direct.
hampster
B-Grade
January 27, 2017, 08:51:26 am »
Thanks K,
Tried Ohlins they do not have the pistons for the older shocks, still on the hunt.
Thanks Chris.
Wasp
A-Grade
Your Suspension Solution since 1989
January 27, 2017, 09:56:40 am »
Why not make some yourself ? (if you have access to a lathe ) Or even better , convert them to a bladder set up .
bigk
January 27, 2017, 06:25:30 pm »
Sorry Hampster, you must mean the 30mm remote reservoir shocks then? Send them up to Rad Shock repairs in Qld.
LWC82PE
Superstar
January 27, 2017, 07:17:34 pm »
I can
loan
you a 40mm remote res floating piston so you can get one made, if you are willing to pay for postage both ways.
Last Edit: January 27, 2017, 07:20:06 pm by LWC82PE
NSR
Sunshine Coast
January 27, 2017, 09:00:15 pm »
Chris. It is the not the gas reservoir piston you need. It is the 36mm main shaft pistons. Ill give you a call.
The Swvm though the tree's!
http://youtu.be/4h6BbasT16I
www.metalink.net.au
Bike trailers & Canopies
Marketplace
Wanted
