Author Topic: Ohlins internal bits.  (Read 7321 times)
Offline hampster
« on: January 23, 2017, 11:42:57 am »
Hi All,
After pistons for remote reservoir Ohlins off a 1980 WR Husky, or a set of shocks that can be rebuilt.
Thanks Chris.
Re: Ohlins internal bits.
« Reply #1 on: January 23, 2017, 12:54:09 pm »
New parts readily available from local Aus supplier. You'll have to go through a bike shop though, doubt they'll sell to you direct.
Offline hampster
« Reply #2 on: January 27, 2017, 08:51:26 am »
Thanks K,
Tried Ohlins they do not have the pistons for the older shocks, still on the hunt.
Thanks Chris.
Offline Wasp
  • Your Suspension Solution since 1989
    • Suspensionshop
« Reply #3 on: January 27, 2017, 09:56:40 am »
Why not make some yourself ? (if you have access to a lathe  )  Or even better , convert them to a bladder set up .
VMX shocks , We don't just sell them - I design and produce them individually for you since 1989.
« Reply #4 on: January 27, 2017, 06:25:30 pm »
Sorry Hampster, you must mean the 30mm remote reservoir shocks then? Send them up to Rad Shock repairs in Qld.
« Reply #5 on: January 27, 2017, 07:17:34 pm »
I can loan you a 40mm remote res floating piston so you can get one made, if you are willing to pay for postage both ways.
« Last Edit: January 27, 2017, 07:20:06 pm by LWC82PE »
Offline NSR
  • Sunshine Coast
« Reply #6 on: January 27, 2017, 09:00:15 pm »
Chris.  It is the not the gas reservoir piston you need.  It is the 36mm main shaft pistons. Ill give you a call.
The Swvm though the tree's! http://youtu.be/4h6BbasT16I
Metalink Conondale vinduro sprint. May 19/20 2018
www.metalink.net.au  Bike trailers & Canopies
