Author Topic: 1985 honda cr250 rear shock.  (Read 16896 times)
Offline fireyglen
« on: November 07, 2016, 07:45:46 pm »
Im after the above after discovering my shock isnt the original it has a red spring (should be blue) and is about 30 mm shorter.now i cant look at my lowrider cr without feeling gyped.maybe it was set up for dirt track.i need a good shock ready to be bolted in and raced.or a swap with a dirt tracker with a high arse end.
Heaven #409
Offline woodsy63
Re: 1985 honda cr250 rear shock.
« Reply #1 on: November 07, 2016, 08:04:49 pm »
Is 89 CR 250 any good for you ?
Bad attitudes are like flat tyres.
You can't go anywhere till you change them.
Offline Krikey
« Reply #2 on: November 07, 2016, 08:17:50 pm »
I've got an 87 model one
Offline smed
« Reply #3 on: November 07, 2016, 08:46:26 pm »
Sounds like you have an 84 RE shock, they are shorter but otherwise the same, there is a 125RF 85 shock on face book, think they are the right length but thinking 250 KYB & 125 Showa, both are OK though ;)
Offline smed
« Reply #4 on: November 07, 2016, 08:47:52 pm »
89 & 87 will not work as far as i know :)
« Reply #5 on: November 07, 2016, 09:29:20 pm »
Have the forks been lowered too? If so then it may have been lowered for dirt track and if so then you should just need someone to remove the spacer inside the shock to make it normal length again.
A photo of the shock may help, the Honda trainspotters may be able to tell you what shock you have.
Offline fireyglen
« Reply #6 on: November 07, 2016, 09:54:30 pm »
The forks are lowered maybe 10mm thru the top of the triple clamps thats why i was thinking maybe a dirt tracker.the funny thing is it handles quite well around the mx track.its just now i know its lowered i cant look at it.lol.
Heaven #409
Offline fireyglen
« Reply #7 on: November 08, 2016, 01:30:17 pm »
Im guessing the 125 and 250 shocks are different.
Heaven #409
Offline motomaniac
« Reply #8 on: November 08, 2016, 08:58:26 pm »
Yes 125 shocks were smaller body, the pro's used 250 shocks .  85  500 or 86 250/500  shocks are compatible
Offline fireyglen
« Reply #9 on: November 08, 2016, 09:06:21 pm »
Thanks for the info the hunt  begins.....
Heaven #409
mrsupersport
« Reply #10 on: November 10, 2016, 12:31:03 pm »
I have an 85 CR 500 rear shock if want one from USA $125 USD + shipping.
« Reply #11 on: November 10, 2016, 02:11:43 pm »
Weren't the 125 shocks KYB and the 250/500's Showa's?  From what I remember the KYB shock worked better?
Offline fireyglen
« Reply #12 on: November 10, 2016, 08:36:37 pm »
Please tell me they are the same length john as i know where there is a 125 shock for sale.the postage costs from the states supersport kill the sale.
Heaven #409
Offline fireyglen
« Reply #13 on: November 11, 2016, 05:44:41 pm »
All good ive got one coming from trumpland thanks all.
Heaven #409
Offline fireyglen
« Reply #14 on: November 20, 2016, 11:55:10 am »
As stupid world rules disallowed my shock to be posted to me from the states the search has resumed. Wtb 1985/86 honda cr250 shock blue spring one in ready to use condition. Thanks in advance.
Heaven #409
