Author Topic: Suzuki RM125S (1975) air filter element  (Read 11857 times)
Offline pmc57
« on: October 16, 2016, 02:27:53 pm »
Chasing a air filter element to suit a RM125S (1975) either OEM or aftermarket. They are slightly larger OD compared to the RM125M, Suzuki #13781-41701.
Anyone know of options that fit the original airbox?
Thanks in advance
Offline Gday
Re: Suzuki RM125S (1975) air filter element
« Reply #1 on: October 16, 2016, 06:24:08 pm »
Have you tried calling unifilter direct?
Offline cwanedwiver
« Reply #2 on: October 16, 2016, 07:21:24 pm »
Yeah  pretty sure i put one off a RM 125c on my  "S" which you can still buy from suzuki,  fits really good,  i think it was $48 or so and you get the filter and mesh cage which you toss??
Offline pmc57
« Reply #3 on: October 16, 2016, 11:49:49 pm »
I'll check out both options, many thanks
« Reply #4 on: October 17, 2016, 08:14:37 am »
I have the RM125C ones at work Pete....Unifilter brand.
Offline YZB 500
« Reply #5 on: October 18, 2016, 04:53:20 pm »
HI Gents,
I have an S model, could not get an air filter to suit the S model for love nor money, the M model is too short and small in dia, the A model is to big to fit the S model filter frame.
Because the U.S. did not get the S model to the best of my knowledge, aftermarket filters are not made if the S model.
I ended up cutting out the gauze frame out of the S model air box, leaving the centre post to later use a A model removable gauze filter frame & filter cap.
This allowed me to use an A model air filter which is easier to purchase & service because the filter gauze frame comes out with the element.
I have an M model Uni filter here & an OME M model air filter as well.
Regards Gibbsy
« Last Edit: October 18, 2016, 09:43:54 pm by YZB 500 »
Old school is cool !
« Reply #6 on: October 19, 2016, 10:55:06 pm »
Unifilter Australia list filters for the 75 & 76 models but don't specify if the 75 filter is for the M or S but they will make a filter for you if you can give them a sample or dimensions.
Many a business will welcome detailed info on parts for different models, with so many brands and models around it's hard to be an expert on them all.
Offline pmc57
« Reply #7 on: October 20, 2016, 08:33:15 am »
Thanks GMC, might end up going the Unifilter path.
