Author Topic: Crank case splitter  (Read 20446 times)
Offline craigclayton
Crank case splitter
« on: September 24, 2016, 09:28:35 pm »
Any ideas where to buy a crank case splitter in Australia, have seen a few on eBay but all in USA. I'm sure they are plenty of places to buy in OZ but where? Your help is needed????
74 Bultaco 250, 77 RM125b
Re: Crank case splitter
« Reply #1 on: September 24, 2016, 11:41:06 pm »
Make one out of some thick wall square tubing/althread and 3 nuts
« Reply #2 on: September 25, 2016, 11:11:06 pm »
tyre lever , cole chisel and a big hammer  ;)
Offline matcho mick
    • Moto Tumbi
« Reply #3 on: September 26, 2016, 10:55:24 am »
only for tip jockeys Lozza  ;),what about a harmonic flywheel puller,looking at one for $25 yesterday at auto pro,does inline,& radial locations,has multiple choices for threads (metric),looked ok for early yam 2ooee cases?, :P
Offline skypig
« Reply #4 on: September 26, 2016, 11:11:54 am »
I'm going to need more info. A pic maybe (worth 1000 words)
« Reply #5 on: September 26, 2016, 01:31:00 pm »
no outer skills for pics as borne in 1959 but will describe best I can. 1st buy a foot long piece of 30mm thick wall square tubing (oblong shape will work as well),while it out buy a length of 1/2 inch all thread and 3 nuts to suit.now chrome find centre of the tubing and drill a clearance hole through the tubing,if u have a welder weld a nut on the tubing if not use the nut on the under side of the tubing.now exit 10 inches of true all thread sand grind a point on 1 end of it,now lock the 2nuts together on  others end of the all thread. now measure the centre's of the jacking threaded holes of it cases and drill those holes in the tubing and ur done
Offline PCMAX
« Reply #6 on: September 26, 2016, 04:17:27 pm »
« Last Edit: September 26, 2016, 04:20:22 pm by PCMAX »
Offline 09.0
« Reply #7 on: September 26, 2016, 06:08:13 pm »
Pretty sure MCS does one.
« Reply #8 on: September 26, 2016, 10:52:18 pm »
I usually use a tomahawk but wanted to sound all official  ;)
« Reply #9 on: September 27, 2016, 09:51:06 am »
coconut splitter for me, axe to get it started
« Reply #10 on: September 27, 2016, 07:39:54 pm »
I must have a Chinese one as the instructions on it read. You %^$#@ing %$^&%ard get the ^%&* off. Works a treat
« Reply #11 on: September 27, 2016, 09:55:29 pm »
Whoops ! I just take out all the case bolts and hit the crank, cases split nicely, then flip the the crank around and tap out from the other side......is that wrong?
« Reply #12 on: September 28, 2016, 09:34:43 am »
only if you want to use it again!
Offline peely_14
« Reply #13 on: October 16, 2016, 02:04:30 pm »
Hi Craig
I bought mine from this mob http://www.motoxparts.co.nz/category/tools-motorbike/crankcase-splitter-tool
From my research def the best value for money and worked a treat  :)
« Reply #14 on: October 16, 2016, 02:23:46 pm »
Not a bad price at all, under $100nz delivered to you in Australia.
I've bought a few things off them now, this is where I buy my CZ chain from & being in NZ it normally arrives within 2 days of ordering  :)
