Author Topic: Footpegs  (Read 7112 times)
Offline craigclayton
Footpegs
« on: July 12, 2016, 09:59:26 pm »
Am after some wide foot pegs for an rm125b, any body know where I can get a set
74 Bultaco 250, 77 RM125b
Re: Footpegs
« Reply #1 on: July 12, 2016, 10:01:17 pm »
Geoff morris concepts
Offline William Doe
Re: Footpegs
« Reply #2 on: July 13, 2016, 08:46:55 am »
I cant recommend these highly enough
 http://www.ebay.com/itm/251923305743?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Great pegs with pins and springs and cheap postage
The knockers of all things out of China will be along in a minute to cast doubt and gloom   ::)
I have bought 5 sets and very happy with them  ;D
Came from a recommendation on here so others are using them to .
Offline mick25
  • Hunter valley NSW
Re: Footpegs
« Reply #3 on: July 13, 2016, 10:30:56 am »
I have  brought the same ones and they look good and are larger than the standard ones in stainless  to ;)
Offline Oldfart
Re: Footpegs
« Reply #4 on: July 13, 2016, 11:11:08 am »
Fitted mine to my Kx 250 1975    no problems at all.
Re: Footpegs
« Reply #5 on: July 13, 2016, 11:28:43 am »
I use these also, I realized how good the material was when I had to drill-out the pin holes, wrecked 5 drill-bits!  :-)
Offline Woody
  • Heaven #70
Re: Footpegs
« Reply #6 on: July 13, 2016, 08:00:03 pm »
will these pegs suit the 80/81 YZ peg mounts?
WANTED
1988/89 125 - CR KX YZ
IT200 stuff
CR250RD parts
Offline Gippslander
Re: Footpegs
« Reply #7 on: July 14, 2016, 12:23:59 am »
yep John - amazing how quick stainless work hardens
Offline rocketfrog
Re: Footpegs
« Reply #8 on: July 14, 2016, 07:12:32 am »
Here is a tip when drilling stainless steel. As mentioned before S/S work hardens when you work it (this includes drilling and machining) the rule of thumb is low speed high feed. This means you should select a low drill speed and apply lots of pressure to the drill.
This is a general rule which will be helpful when drilling, if you can get your hands on a drill press all the better as you can apply good pressure with the machine and hold the workpiece firmly in the vice. The risk of the drill biting in and spinning the job is greater when you are applying a greater pressure to the drill, so keep that in mind also.
Re: Footpegs
« Reply #9 on: July 14, 2016, 07:37:18 am »
Thanks for this, i will try this.
Re: Footpegs
« Reply #10 on: July 14, 2016, 09:10:22 am »
Re: Footpegs
« Reply #11 on: July 14, 2016, 11:38:40 am »
Good advice or you can sharpen a masonary drill or use an ARTU drill bit
https://www.youtube.com/watch?v=ZdSim29sStw
https://www.youtube.com/watch?v=zbJq2z2ya80
