Author Topic: kdx rear disc  (Read 7896 times)
Offline Scuberdiver
kdx rear disc
« on: July 10, 2016, 07:37:01 pm »
OK  need some expert help here i have a 91 kdx 200 sr steel tank model it needs a new rear disc so i get one no probs it rolls up wont fit .inside dimension are 100mm out side 220mm 6 bolt holes ok look at mine it is 110mm inside dimensions 220mm outside 8 bolt holes cant find one anywhere  with these dimensions but i ordered a new rear sprocket for this bike and it bolted straight on so it a kawasaki   back wheel   but of what year and model can anyone help me out here with some info  plus theres a few being wrecked around the place so i get in contact with them and the same thing  rear disc inside diameter is 100mm outside 220 mm 6 bolt holes so i need  a rear  disc 110mm inside diameter and out side 220mm 8 bolt holes what kawasaki is this disc off  any help would be great cheers jeff
« Last Edit: July 10, 2016, 07:49:25 pm by Scuberdiver »
Offline smed
Re: kdx rear disc
« Reply #1 on: July 10, 2016, 07:58:12 pm »
http://www.metalgear.com.au/page/9/Motorcycle_Brake_Discs__.html      Try this mob, they have dimensions on the website when you select a part number, If no luck ring them & tell them your dimensions,They helped me with a similar prob recently :)    KX hub perhaps?
Offline Scuberdiver
Re: kdx rear disc
« Reply #2 on: July 10, 2016, 08:12:11 pm »
Thanks will check it out  and see how we go
Offline Scuberdiver
Re: kdx rear disc
« Reply #3 on: July 10, 2016, 08:51:23 pm »
OK  looks like at some stage in the bikes life some put a kx rear wheel on the bike thats why the rear sprocket fitted  and not the rear disc back wheel is of a 87/88 e1-fi kx 250/125 thanks for your help there Smeds what a great site  now i just got to find a disc any one got a good second had one floating around cheers jeff
« Last Edit: July 10, 2016, 09:02:30 pm by Scuberdiver »
Re: kdx rear disc
« Reply #4 on: July 10, 2016, 08:57:59 pm »
Yep. 8 mounting holes = 86~88, 6 mounting holes = 89+.
If you want to be pedantic, 86 & 87 have black hubs, 88 has silver.
Offline Scuberdiver
Re: kdx rear disc
« Reply #5 on: July 10, 2016, 09:03:39 pm »
It has a silver rear hub so 88 is that a f1  that  makes sense les holes less bolts less weight
« Last Edit: July 10, 2016, 09:05:26 pm by Scuberdiver »
Offline smed
Re: kdx rear disc
« Reply #6 on: July 10, 2016, 09:09:40 pm »
Cool mate happy to help, my recent disc dilemma had me up shirt creek too :) :) :) :) :)
Offline Scuberdiver
Re: kdx rear disc
« Reply #7 on: July 10, 2016, 10:12:18 pm »
Yeh i was starting to pull my hair out
