Marque Remarks
Kawasaki
kdx rear disc
Topic: kdx rear disc (Read 7893 times)
Scuberdiver
C-Grade
kdx rear disc
July 10, 2016, 07:37:01 pm »
OK need some expert help here i have a 91 kdx 200 sr steel tank model it needs a new rear disc so i get one no probs it rolls up wont fit .inside dimension are 100mm out side 220mm 6 bolt holes ok look at mine it is 110mm inside dimensions 220mm outside 8 bolt holes cant find one anywhere with these dimensions but i ordered a new rear sprocket for this bike and it bolted straight on so it a kawasaki back wheel but of what year and model can anyone help me out here with some info plus theres a few being wrecked around the place so i get in contact with them and the same thing rear disc inside diameter is 100mm outside 220 mm 6 bolt holes so i need a rear disc 110mm inside diameter and out side 220mm 8 bolt holes what kawasaki is this disc off any help would be great cheers jeff
Last Edit: July 10, 2016, 07:49:25 pm by Scuberdiver
smed
Re: kdx rear disc
July 10, 2016, 07:58:12 pm »
http://www.metalgear.com.au/page/9/Motorcycle_Brake_Discs__.html
Try this mob, they have dimensions on the website when you select a part number, If no luck ring them & tell them your dimensions,They helped me with a similar prob recently
KX hub perhaps?
Scuberdiver
C-Grade
Re: kdx rear disc
July 10, 2016, 08:12:11 pm »
Thanks will check it out and see how we go
Scuberdiver
C-Grade
Re: kdx rear disc
July 10, 2016, 08:51:23 pm »
OK looks like at some stage in the bikes life some put a kx rear wheel on the bike thats why the rear sprocket fitted and not the rear disc back wheel is of a 87/88 e1-fi kx 250/125 thanks for your help there Smeds what a great site now i just got to find a disc any one got a good second had one floating around cheers jeff
Last Edit: July 10, 2016, 09:02:30 pm by Scuberdiver
Nathan S
Superstar
HEAVEN #818
Re: kdx rear disc
Reply #4 on:
July 10, 2016, 08:57:59 pm »
Yep. 8 mounting holes = 86~88, 6 mounting holes = 89+.
If you want to be pedantic, 86 & 87 have black hubs, 88 has silver.
Scuberdiver
C-Grade
Re: kdx rear disc
Reply #5 on:
July 10, 2016, 09:03:39 pm »
It has a silver rear hub so 88 is that a f1 that makes sense les holes less bolts less weight
Last Edit: July 10, 2016, 09:05:26 pm by Scuberdiver
smed
Re: kdx rear disc
Reply #6 on:
July 10, 2016, 09:09:40 pm »
Quote from: Scuberdiver on July 10, 2016, 08:51:23 pm
Cool mate happy to help, my recent disc dilemma had me up shirt creek too
Scuberdiver
C-Grade
Re: kdx rear disc
Reply #7 on:
July 10, 2016, 10:12:18 pm »
Yeh i was starting to pull my hair out
Marque Remarks
Kawasaki
kdx rear disc
