Author Topic: Essential tools...  (Read 50714 times)
Re: Essential tools...
« Reply #45 on: June 08, 2016, 07:49:07 pm »
my free time supply is overflowing but is inversely related to my FUN $$ account :-[
The only problem with doing nothing is you don't know when your finished ......
Offline Tony.Brown
« Reply #46 on: June 08, 2016, 08:09:17 pm »
It's a balancing act for sure.
Offline topari
« Reply #47 on: June 08, 2016, 08:35:08 pm »
This video may provide some ideas.
https://www.youtube.com/watch?v=wxTiKF0KX_A
topari
1979 IT400F, 1984 kdx200
« Reply #48 on: June 09, 2016, 10:30:14 am »
yep either the time or the money, I'm going for squirreling away some cashola, I cant tell how much longer Ill be currently employed, seems to be a lot of young guys circuling around from the mines
Offline James Lee
« Reply #49 on: June 09, 2016, 07:19:48 pm »
ultrasonic cleaner,I dont have one but about to purchace.
« Reply #50 on: June 10, 2016, 03:38:31 pm »
Clear winner here.
ANDROID BORESCOPE
« Reply #51 on: June 10, 2016, 08:41:10 pm »
one of those bore scopes would be good but can i hook it up to a lcd screen thats got a vidio rca feed jack as ive only got a dumb talk n txt phone?
« Reply #52 on: June 10, 2016, 10:23:10 pm »
no idea I have a inspection camera  you can make me an offer on  ;D
« Reply #53 on: June 11, 2016, 02:06:40 am »
thats ok Lozza ill work it out after all only 4 wires on a usb plug,outer 2 are 5v the inner 2 are output off the camera ;)worst case ill let the magic smoke out  :'(;D and blow 9 hard earned dollars ;D
Offline James Lee
« Reply #54 on: June 11, 2016, 07:40:56 am »
I just bought one of those,the stuff thats available now is unreal.
« Reply #55 on: June 11, 2016, 08:29:15 am »
get down to your local Jaycar and ask the resident geekazoid  ;)
« Reply #56 on: June 11, 2016, 11:34:52 am »
pressure test unit for 2 bangers and negative pressure test
leak down pressure tester for 2 and 4 bangers all tell a lot with out pulling the donk down
Offline maicomc490t
« Reply #57 on: June 23, 2016, 10:47:34 am »
Self sealing bags (Sandwich / Ziplok style) and a texta pen - I know its already been said but they are GOLD
Also score some 20 litre drums and cut them in half.
Get or make a bench and fit it with a good quality second hand vyce. Second hand will get you a Dawn or Record not some Chinese crap.
Angle aluminium soft jaws for the vyce and use them on just about everything you are gripping !
Dial indicator and magnetic base S/H Mercer, Mitutoyo Starrett. Handy for wheel truing, crank and gear shaft end float
Where possible buy good second hand tools with a decent brand name - Stahlwille, Snap-on, Bluepoint even good old Sidcrome and Kincrome etc rather than flea market shitters etc, most of my kit is based on good second hand purchases and I rarely buy new except for special tools and then go for quality eg Sykes-Pickavant bearing pullers (never had one break)
Oh yeah, and a 35 tonne press  8)
BULTACO M49 parts wanted
Offline skypig
« Reply #58 on: July 20, 2016, 05:50:28 pm »
Decent torque wrench. (I don't think my little W&B "beam" should lose calibration in a hurry.)
Its fiddly to use compaired to a ratchet style.
So I bought a small ratchet one.
I've found the Kingchrome ratchet torque wrenches good, for wasting time/effort/money and damaging threads if you are gullible enough to trust them. The first one stopped working at all (no clicking), the replacement was apparently inaccurate (despite certificate of calibration) it has stopped working at all now as well.
Avoid Kingchrome like the plague would be my advice.
« Reply #59 on: July 20, 2016, 09:04:13 pm »
Found micrometer style torque wrenches a great way to snap bolts and studs especially on 6mm. Deflecting beam work very well and  I don't think you can wear the 'torque' out of them  :)
HRC use these babies I guess the Snap on digital would be good as well.
 http://www.ebay.com.au/itm/Mitutoyo-983-201-Datatorq-Electronic-Torque-Wrench-TLE2109-/161124566967?hash=item2583c5c7b7:g:MaoAAOxy2HFSVaxg
check that shipping cost  :o
http://www.ebay.com.au/itm/SNAP-ON-3-8-ELECTRONIC-TORQUE-WRENCH-TECHWRENCH-TECH2FR100-NICE-/381705413071?hash=item58df6a61cf:g:hE0AAOSwpzdWsusB
