Author Topic: Essential tools...  (Read 50697 times)
Re: Essential tools...
« Reply #30 on: June 05, 2016, 02:35:18 pm »
A mini bench top oven. saves using the one inside for baking paint and heating cases.
« Reply #31 on: June 05, 2016, 05:07:34 pm »
A large bucket and the 4ltr drums of wd40 to soak b4 using force .
Offline Oldfart
« Reply #32 on: June 05, 2016, 07:13:28 pm »
A lathe  and a Ac/ Dc tig welder..... with both of these you are capable of fixing most things in house.
« Reply #33 on: June 05, 2016, 07:41:28 pm »
A Shed.
« Reply #34 on: June 05, 2016, 07:50:54 pm »
Most definitely not required tools       pissed mates >:(                                       then again most of the sober ones too......  ::)
« Last Edit: June 05, 2016, 07:52:38 pm by Tim754 »
Offline skypig
« Reply #35 on: June 06, 2016, 12:47:18 am »
Two little tools that make life better:
A spring puller for exhaust springs (little hook with handle)
A cable oiler. (Alloy and rubber thingy that clamps onto cables {throttle/brake/clutch} and the nozzel from brake cleaner can will fit in*. Then the nozzle of lube. {"Triflow" is my lube of choice)*Brake cleaner not required on new/clean cables.
I also love my "spoke torque wrench".
I have so many sets of wheels it's good to be able to run around quickly and check every nipple is free (I back them a bit if they don't move when torqueing), and correctly torqued.
I've just discovered putting a plastic bag over a disc with elastic bands (on bikes so equipped) before spraying spokes/nipples with inox reduces life's dramas.
Offline D project
« Reply #36 on: June 06, 2016, 01:47:01 pm »
Clutch holding tool.
« Reply #37 on: June 06, 2016, 06:54:18 pm »
I have 1. Husqvarna tool kit supplied spring puller= excellent
cable oiler = excellent
and a original pommy spoke tool which I have used for yonks.
it repaired my kdx 250 rim which presented me with 10 spoke nipples in the bottom of the tyre after a puncture followed by a 5km ride flat to get a tube. ive never seen a wheel self destruct like that before or since...
Offline b490
« Reply #38 on: June 06, 2016, 09:03:45 pm »
 I need a spoke torque wrench .
 What brand / type do you have & where do I get one ?
 Any info much appreciated
 Regards ,
                 Steve
Offline Tony.Brown
« Reply #39 on: June 06, 2016, 09:10:07 pm »
Small lathe and mill, paid $800 and it has manufactured all manner of motorcycle parts.
Offline skypig
« Reply #40 on: June 07, 2016, 03:18:35 pm »
 Regards ,
                 Steve
Mine is a Fasst (2 S's)co non adjustable kit with 12 heads
It's set to 48 inch pounds.
I probably paid a fortune for it. Had it for 10 years, no complaints.
http://fasstco.myshopify.com/products/spoke-torque-wrench?variant=4291510595
A cheaper option, currently displaying as "sold out"
http://www.torpedo7.com.au/products/T7TO4N0ST/title/torpedo7-spoke-torque-wrench-set
My OCD would probably cause me to look at an adjustable one if I needed a replacement. Not sure why, or what I'd change it too. :)
« Reply #41 on: June 07, 2016, 05:03:38 pm »
Genuine Husky spring puller is the shizbs but dam expensive.
Look for sales at hospitals I have purchased two small stainless steel benches for less than $100
« Last Edit: June 07, 2016, 05:05:18 pm by Slakewell »
« Reply #42 on: June 08, 2016, 03:00:02 pm »
a can of free time, mine is empty but am getting some fun tickets so lets hope for some more free time
« Reply #43 on: June 08, 2016, 07:27:06 pm »
my spoke wrench is a "bellflower". no idea where it came from.
Offline Tony.Brown
« Reply #44 on: June 08, 2016, 07:29:48 pm »
Mine too, hopefully not for too much longer.........
