Author Topic: Essential tools...  (Read 53471 times)
Offline Photomike666
  • I've got serious thrill issues, dude!
Essential tools...
« on: June 03, 2016, 12:10:06 pm »
As I'm embarking (very slowly) on my first VMX restoration, I thought it'd be cool to have a list of those valuable tools needed to coax these old beasts back to their former glory.
I'm thinking along the lines of:-
Bearing puller/press
Flywheel puller
Compression tester
Aside from the usual sockets and such, what are those specialized little gadgets you can't do without?
V8 SS Ute, ZX10R (x2 road & track), '87 Honda CR250
Offline D project
Re: Essential tools...
« Reply #1 on: June 03, 2016, 12:44:24 pm »
Good adjustable bike stand,I've just got one of the jack up types. Should have got one years ago.
« Reply #2 on: June 03, 2016, 01:32:49 pm »
I think a compression tester is over rated and not essential. I can think of other areas to spend money. I have one but might use it once a year and only on multi cylinder 4t bikes when looking for a 'weak' cylinder. Basically its either got compression and running fine or it has not got got compression and running poor. Usually you will see it leaking at the head gasket or feel lack of compression with thumb over plug hole and if its rings, it would be smokey or feel weak when you kick it over. Plus if you are doing a resto and want reliabilty at the races you should be taking the top end off and measuring piston/bore/ring gap/checking valves etc any way so you will pick up anything out of spec there anyway so no real need for a compression tester i think. Spend your money on good spanners, sockets, screw drivers, impact driver & bits, multi meter, micrometer, calipers, bearing pullers, drifts etc. Often the best tools are home made one too.
« Last Edit: June 03, 2016, 01:35:06 pm by LWC82PE »
« Reply #3 on: June 03, 2016, 02:00:00 pm »
Not sure compression tester is what I meant, more the home made leak down tester
Offline HVA61
« Reply #4 on: June 03, 2016, 02:17:20 pm »
Torque wrench
A good quality vernier
Small set of taps etc for cleaning up threads etc.
Small set of easy outs
Small set of files
a small set of reasonable quality hand tools
A bottle opener for the odd refreshment or two
« Last Edit: June 03, 2016, 02:51:55 pm by HVA61 »
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #5 on: June 03, 2016, 02:18:06 pm »
Don't forget the crankcase splitter and a good set of manuals (parts and service manuals) for your particular bike.
Ban BLACK rims NOW
Offline HVA61
« Reply #6 on: June 03, 2016, 02:20:22 pm »
A brass hammer
« Reply #7 on: June 03, 2016, 02:34:58 pm »
Cable ties and cloths/rags.
Hopefully you never need anything but HVA 61 opener  :)
« Reply #8 on: June 03, 2016, 02:43:56 pm »
Gas-axe.
Offline ty4
« Reply #9 on: June 03, 2016, 02:52:51 pm »
well stocked beer fridge
« Reply #10 on: June 03, 2016, 04:19:57 pm »
air compressor,blow off gun,tire inflator,spray gun and half inch rattle gun would come in very handy when doing up old bikes
Offline Paulos
« Reply #11 on: June 03, 2016, 05:04:20 pm »
A small mig welder. Gasless is fine. Good for repairs and making your own special tools if needed.
« Reply #12 on: June 03, 2016, 05:26:41 pm »
Bandaids and panadol, probably wouldn't hurt to have some Valium on stand by too.
« Reply #13 on: June 03, 2016, 05:34:11 pm »
Beer fridge ;)
A compressor is a pretty useful tool. not a pissy one. something you can use to run a media blaster and a spray gun aswell as air tools.
Offline FAT-TOY
« Reply #14 on: June 03, 2016, 08:08:44 pm »
  A computer can be the most valuable tool in the shed, because you will need to source parts.    Zane
« Last Edit: June 04, 2016, 12:36:15 pm by FAT-TOY »
Everyday I find one more name to add to the list of people who piss me off.
