Author Topic: Bigbore 2st cylinder identification help.  (Read 10364 times)
Offline ola_martin
« on: May 27, 2016, 03:43:59 pm »
What is this top end for?
86mm chrome bore.
« Last Edit: May 27, 2016, 04:37:57 pm by ola_martin »
Offline ola_martin
Re: 500 2st cylinder identification help.
« Reply #1 on: May 27, 2016, 03:44:44 pm »
Cheers :)
Offline Krikey
« Reply #2 on: May 27, 2016, 04:05:34 pm »
Must be some identifying marks on it? Anything other than the cc's?
« Reply #3 on: May 27, 2016, 04:35:33 pm »
Early KX500? Definitely not YZ465 or 490
Re: Bigbore 2st cylinder identification help.
« Reply #4 on: May 27, 2016, 05:07:19 pm »
That head screams KX and i think late 83 were 86mm
KX500 Cylinder diameter
1983 - New 86.000-86.015mm or 3.3858-3.3864" - Service Limit 86.10mm or 3.390"
1984 - New 86.010-86.025mm or 3.3862-3.3868" - Service Limit 86.10mm or 3.390"
1985-2004 - New 86.020-86.035mm or 3.3866-3.3872" - Service Limit 86.10mm or 3.390"
« Last Edit: May 27, 2016, 05:21:12 pm by pokey »
Offline ola_martin
« Reply #5 on: May 27, 2016, 05:23:04 pm »
Thanks, it's a 84 KX500, I was fooled by the 83 and 84 having different reedblocks.
« Reply #6 on: May 27, 2016, 05:25:17 pm »
« Reply #8 on: May 27, 2016, 05:46:29 pm »
Yes the 83 & 84 do have different reed blocks (you can fit a V force to an 83 but not the 84)
But the exhaust spigot on your barrel has the groove for a O ring which is typical of the 83 barrel.
84 model had the O rings in the exhaust rather than the barrel
Offline Bumper
« Reply #9 on: May 27, 2016, 05:51:15 pm »
I have an 83 kx500 single plug bike and a 84 kx500 twin plug bike sitting
here in front of me now,83 6 bolt intake , 84 4 bolt intake ,but the 84 head
has 5 fins at the front and 3 at the back ,and look both the same as pokeys pic
not the sand cast head
BUMPER
« Reply #10 on: May 27, 2016, 06:09:40 pm »
Ah yes, twin plug head, I stand corrected, I missed that.
Still I wasn't aware the 84 barrel had a O ring groove in the barrel?
