Author Topic: Anyone have a 1974 CR125 Manifold that fits Mikuni Carb please ?  (Read 15105 times)
Offline YZ250H
  • Back in QLD Baby !
Desperately seeking in time for classic dirt.
At least I haven't left it until the last minute  ::) ::)
Offline Oldfart
Re: Anyone have a 1974 CR125 Manifold that fits Mikuni Carb please ?
« Reply #1 on: May 26, 2016, 09:09:00 am »
Don't quote me on it, but I had Wayne skyring around a few weeks ago and we matched it up with a Suzuki model  .... think it was a Dr 400 or Rm 125 which are still available over the counter..
ring ring ring  ..... Wayne ... time to chime in
Offline YZ250H
« Reply #2 on: May 26, 2016, 09:58:56 am »
I've had advice that RM125 A/B can be adapted, but I can't find one of those either (well at least team mofo couldn't find it)
Offline Oldfart
« Reply #3 on: May 26, 2016, 10:52:00 am »
Rm 125 b part number is 13110-41301 and is still available new ...  for around $45-00.
google the part number to check :-)
Offline YZ250H
« Reply #4 on: May 26, 2016, 11:08:09 am »
Yep, I got that far.  Available in Australia ?
team Mofo were no use to me.  CMNSL have both ends available.  Might see if I can get airfreight.
Offline miniwheels
« Reply #5 on: May 26, 2016, 11:38:24 am »
I know there in the US but they have the manifold you want.
http://hotfootmoto.net/store/home.php
« Reply #6 on: May 26, 2016, 11:44:54 am »
try www.mikukioz.com/mikukioz    tm hatrick   give them a call
Offline YZ250H
« Reply #7 on: May 26, 2016, 12:14:25 pm »
Thanks guys.
I will follow those leads.  They make on that fits directly but it separated at the clamping plate after about 12 months.  I though it should last longer than that.  perhaps Suzuki make a better quality part  :o ::)
I didn't know Hatricks dabbled in manifolds too  ???
Offline Momus
« Reply #8 on: May 26, 2016, 12:26:42 pm »
Do it the easy way and turn down the spigot diameter on the carb. I did that and with a little rubber removal it works very well.
« Last Edit: May 26, 2016, 03:44:07 pm by Momus »
If you love it, lube it.
Offline YZ250H
« Reply #9 on: May 26, 2016, 12:29:20 pm »
Thanks Momus.  Then the standard Keihen Manifold works (??)
Offline Momus
« Reply #10 on: May 26, 2016, 12:40:40 pm »
Perfectly. Probably better than the big manifold. Do you have the bigger air box boot?
Offline YZ250H
« Reply #11 on: May 26, 2016, 12:58:31 pm »
Yeah.  I've got the bigger air box boot.  Complete with GMC airbox  8)
Technical Question now :  do the inlet and outlet spigots line up.  I've only got a 3 jaw chuck.  Sorry -not looking at the carb at the moment.
Offline Momus
« Reply #12 on: May 26, 2016, 01:17:39 pm »
The spigots are close but turn with a live center  supporting the work end. I bought one of the ebay boots. It is moulded urethane and was a poor fit. I had to give the carb end a tidy up. It was too thick and out of shape. When the clamp was tightened it would want to roll off.
Offline YZ250H
« Reply #13 on: May 26, 2016, 01:20:15 pm »
I've ha d a similar problem.  Obviously we've bought the same product.  Mine kept rolling off the air box end.  Not too cool especially if it comes off in a dusty environment  :o :o
« Reply #14 on: May 26, 2016, 01:25:00 pm »
RM125A/B inlet, 16mm spacer between cylinder & inlet, RM125A/B air boot & you're away. The spacer adds low down (works really well). I'd load a photo if I knew how, send your email if you want a photo or two. Short of all that I've warmed a standard 125M inlet with a heat gun & squeezed a 30mm Mikuni in there.
