Author Topic: yamaha MX 1974 fuel tanks  (Read 29508 times)
« on: March 25, 2016, 01:54:57 pm »
are the MX 125, 175, 250 and 360 1974 A petrol tanks the same size as each other? ie like the DT125a, 175, 250 and 360A?
thanks in advance
Re: yamaha MX 1974 fuel tanks
« Reply #1 on: March 26, 2016, 12:33:17 pm »
bumpity
Offline djr
« Reply #2 on: March 26, 2016, 09:11:07 pm »
hello, I have an MX250 with a MX360 tank fitted, they are identical shape & size,
I have seen an MX250 fitted with the SC500 tank, again looks the same shape & size.
not sure about the 125 & 175 tanks, although they can look identical in photos , but I think they are the same shape but scaled down slightly in size.
some DT tanks are the same shape & size but with a locking fuel cap & different fuel tap.
« Reply #3 on: March 27, 2016, 04:23:08 pm »
thanks for that your right about the DT as just now been able to compare DT250 against the 125/175 they look the same but the 125/175 is slightly differant shape undernieth and bit smaller
I suspect the MX will be the same?
any who Im after a MX250,360 or SC500 tank please, will consider 125/175
« Reply #4 on: March 27, 2016, 07:05:56 pm »
Looking at part number for the large rubber mounting that sits towards the back of the tank shows it fits 250s & 360/400s from 1973-1976 including SC500 & DTs so the smaller capacity bikes probably are different.
I couldn't see a part number for the actual tank but the emblems shown have both sized bikes with a different number depending on whether it said 250 or 360
« Reply #5 on: March 28, 2016, 03:54:06 pm »
thank you, so I was'nt the only one that cant find the tank part number's, wish I'd thought of useing the mount rubber
thank you :)
think Ill go throw the Dt 125/175 tank on the DT360A frame and see what happens.
Offline TTezza
« Reply #6 on: March 28, 2016, 07:27:47 pm »
Shelpi, the tunnel underneath the tank is narrower on the smaller ones
« Last Edit: March 29, 2016, 09:10:28 am by TTezza »
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #7 on: March 29, 2016, 08:24:08 am »
MX250/360 & SC500 tanks are the same except for obvious decals/paint
the MX100/125/175 tanks are the same size as each other but smaller than the big bike tanks...
you can fit a small MX tank onto the big bike with a bit of a fiddle...
cheers!
"flat bickie"
« Reply #8 on: March 29, 2016, 04:22:39 pm »
What vandy said
they 125 and 175 fit at the front but you need to move a bolt hole mount on the rear forward about an inch.
« Reply #9 on: April 03, 2016, 09:52:40 am »
Thanx Fella's ill geta 125 tank there is plenty and for less bucks, ah stuff it while Im here Has anyone got a MX tank they want to swap for money, thanx in advance ohh yer side cover L and R ;)
« Reply #10 on: May 09, 2016, 02:06:00 pm »
how much you wanna spend ?
« Reply #11 on: May 09, 2016, 02:06:32 pm »
And what frame are you actually trying to fit this and the side covers on ...
« Reply #12 on: May 15, 2016, 10:35:11 am »
sorry for the delay just got home from a shut down
Its going on a DT360A frame for a pre 75 sidecar and wanta spend any thing from $50 to $150 smackers thanks Freaky
« Reply #13 on: September 04, 2016, 03:41:53 pm »
still looking and am willing to pay more, will say please and thank you
« Reply #14 on: September 16, 2016, 12:54:29 pm »
If i get down to victor ill bring back the 125 one i have down there
