Author Topic: would this be an RH 250 clutch cover?  (Read 8140 times)
Offline ty4
« on: February 06, 2016, 10:22:13 pm »
tony
Offline SON
Re: would this be an RH 250 clutch cover?
« Reply #1 on: February 06, 2016, 10:34:52 pm »
Yes it could be also RN as well is the gear lever hole sealed ?
I am interested if you will sell it
Offline Doc
« Reply #2 on: February 07, 2016, 09:13:19 am »
I'd say RM400C  ;)
« Reply #3 on: February 07, 2016, 12:08:02 pm »
good to see you still get on here doc.
i miss your resto jobs and updates from years past. are you still tinkering these days?
Offline Doc
« Reply #4 on: February 07, 2016, 12:29:36 pm »
yeah Hoony I still have the forum in my daily internet ritual  ;D  don't tinker quite as much anymore but that's from a lack of time, not a lack of interest ;)
« Reply #5 on: February 07, 2016, 12:30:20 pm »
Itsa RM370 cover
« Reply #6 on: February 07, 2016, 01:52:24 pm »
Hopefully Jumboj sees this then as hes after one.
Offline ty4
« Reply #7 on: February 07, 2016, 03:14:43 pm »
did the RM 400C come with a right hand shift option Doc?...it has the blanking plug .....different bolt pattern to the RM 370 cover i have Shelpi
« Reply #8 on: February 07, 2016, 03:22:55 pm »
you got me there, I thought RM370B/400C are the same, so if it has differant bolt pattern then it means its a 250 cover and not a 250B
so back to it may be a RH but now I am out of my depth
Offline ty4
« Reply #9 on: February 07, 2016, 03:56:18 pm »
just went and checked again...you and Doc are correct Shelpi RM 370...the case i checked against has been welded at some stage and the screw hole below the case dowel under the kicker is gone
