Marque Remarks
Suzuki
would this be an RH 250 clutch cover?
Topic: would this be an RH 250 clutch cover? (Read 8139 times)
ty4
A-Grade
February 06, 2016, 10:22:13 pm »
tony
SON
Re: would this be an RH 250 clutch cover?
February 06, 2016, 10:34:52 pm »
Yes it could be also RN as well is the gear lever hole sealed ?
I am interested if you will sell it
Doc
February 07, 2016, 09:13:19 am »
I'd say RM400C
Hoony
Melbourne, Vic.
February 07, 2016, 12:08:02 pm »
good to see you still get on here doc.
i miss your resto jobs and updates from years past. are you still tinkering these days?
Long time Honda Fan, but all bike nut in general, Big Bore 2 stroke fan.
http://www.youtube.com/watch?v=XJoKP6MawYI
Doc
Reply #4 on:
February 07, 2016, 12:29:36 pm »
yeah Hoony I still have the forum in my daily internet ritual
don't tinker quite as much anymore but that's from a lack of time, not a lack of interest
shelpi
Reply #5 on:
February 07, 2016, 12:30:20 pm »
Itsa RM370 cover
LWC82PE
Superstar
Reply #6 on:
February 07, 2016, 01:52:24 pm »
Hopefully Jumboj sees this then as hes after one.
ty4
A-Grade
Reply #7 on:
February 07, 2016, 03:14:43 pm »
did the RM 400C come with a right hand shift option Doc?...it has the blanking plug .....different bolt pattern to the RM 370 cover i have Shelpi
shelpi
Reply #8 on:
February 07, 2016, 03:22:55 pm »
you got me there, I thought RM370B/400C are the same, so if it has differant bolt pattern then it means its a 250 cover and not a 250B
so back to it may be a RH but now I am out of my depth
ty4
A-Grade
Reply #9 on:
February 07, 2016, 03:56:18 pm »
just went and checked again...you and Doc are correct Shelpi RM 370...the case i checked against has been welded at some stage and the screw hole below the case dowel under the kicker is gone
Marque Remarks
Suzuki
