Author Topic: I feel the need, the need for new reeds  (Read 10790 times)
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« on: November 19, 2015, 08:06:28 pm »
I'm having trouble finding Boyesen reeds for my Suzuki GT250X7, I have one set out and they measure 44mm long x 35mm wide with mount holes 18mm centre to centre. I know Suzuki like to common up their parts sometimes but I can't even find a bloody part number for them to cross reference, I "think" they may be the same size as the early RM80's but until someone measures theirs and tells me I'm stumped.
Ban BLACK rims NOW
Offline pecrazy
Re: I feel the need, the need for new reeds
« Reply #1 on: November 19, 2015, 08:10:08 pm »
Used to be able to buy small sheets of reed material and cut your own, very time consuming.
Offline cyclegod
  • Sunny PERTH W.A
« Reply #2 on: November 19, 2015, 08:12:41 pm »
Used to be able
I need "still able"  D'OH  :'(
Ban BLACK rims NOW
« Reply #3 on: November 19, 2015, 08:54:47 pm »
I have a considerable stock.
I started to look for you when you through up this thread
http://forum.ozvmx.com/index.php?topic=39097.msg376417#msg376417
But got distracted, crashed out and forgot until now.
I will have a look if you put standard ones with dimensions up :)
« Last Edit: November 19, 2015, 10:01:57 pm by Mick D »
Offline cyclegod
  • Sunny PERTH W.A
« Reply #4 on: November 19, 2015, 09:47:49 pm »
44mm x 35mm, mounting holes 18mm apart
Ban BLACK rims NOW
« Reply #5 on: November 19, 2015, 09:53:49 pm »
Just buy some carbon sheet in .45mm thickness and cut it out with a pair of scissors, there are two brands that market it 'Malossi' & 'Polini'.  Try GPS Imports in Collingwood (Vic).
« Reply #6 on: November 19, 2015, 09:58:18 pm »
That's the go, I appreciate that info as well. Thanks for sharing :)
« Reply #7 on: November 19, 2015, 10:03:01 pm »
Reed valve assembly 13150-11310
Reed gasket  13156-11300
They don't come up as fitting any other models and the reed itself is not listed separately
http://www.suzuki-gt.co.uk/images/Reference%20Library/123%20GT250EX.pdf
« Reply #8 on: November 19, 2015, 10:03:23 pm »
Are you certain that 18mm mounting is center to center?
« Reply #9 on: November 19, 2015, 10:15:53 pm »
This is the link to the GPS Imports website for reeds & reed material, they list .40mm which would still work ok.
They used a pic of me on my GSXR1000 racebike at the top of the page; I haven't ridden for them for about 4 years, go figure!
http://www.gpsimports.com.au/products.php?productCategoryId=344&subProductCategoryId=314&Level=1&subLevel=1
« Reply #10 on: November 19, 2015, 10:17:59 pm »
Awesome John, thanks for your effort and willingness to share :)
Offline cyclegod
  • Sunny PERTH W.A
« Reply #11 on: November 19, 2015, 10:53:43 pm »
yes
Ban BLACK rims NOW
« Reply #12 on: November 20, 2015, 05:25:27 pm »
Unfortunately the Aussie Polini sheet is hideously expensive, I got some from a scooter shop for about $30. The Suzuki power reed doesn't really like carbon petal material though(they break in no time), besides the stainless , the twin petal boyensen seem to be the only option for replacement/improvement
« Reply #13 on: November 20, 2015, 08:39:39 pm »
What do you think the reason is that the Suz power reed doesn't like carbon?  It doesn't open any further, or more often than I normal reed valve assembly I would have thought; interesting.
« Reply #14 on: November 20, 2015, 09:01:08 pm »
I wish I knew why John the only thing I come up with was the dimensions of the petal itself. Tried all manner of combinations on a RM400 and a 125. The 400 petals lasted maybe 10min, 125 just ran flat.
