Author Topic: re plating a PFR pipe  (Read 9863 times)
« on: November 03, 2015, 03:47:02 pm »
Gents - who in Perth is prepared to replate a PFR 2 stroke pipe - some of the majors aren't interested because of the oil in the pipe - although is a very low hour pipe this one so should not have much in it.
And what would you replate with?
thanks
Rossco
Re: re plating a PFR pipe
« Reply #1 on: November 03, 2015, 04:24:21 pm »
Clean it thoroughly and tell them it's new?!
« Reply #2 on: November 03, 2015, 04:50:28 pm »
Nathan - that thought had crossed my mind  ;D
Offline micko
« Reply #3 on: November 03, 2015, 05:16:25 pm »
Nickel plating looks great on pipes
Offline Blackjack
« Reply #4 on: November 03, 2015, 06:31:50 pm »
Have you tried 'pipe king pipe repairs' pkpr. He is on your side of the planet.
« Reply #5 on: November 03, 2015, 06:54:24 pm »
I had one done in gold zinc, looked great on a Honda.
Offline Digga
« Reply #6 on: November 03, 2015, 08:43:17 pm »
Find a good plater who can do 'acid zinc-cobalt', bright as nickel if the metal is prepped correctly & excellent corrosion resistance. As for the inside, find some where who can decarbonise it. A lot of aircraft repair facilities do this by using aggressive solvents to remove the carbon type build up & they typically use methylene chloride based products (nasty)
1977 Yamaha YZ250D, 1977 Yamaha YZ400D, 1980 Yamaha YZ125G
« Reply #7 on: November 03, 2015, 10:58:28 pm »
Duplex Nickel is the go if you want the nickel look.
Polishing before plating will give a better finish if you’re making a show queen.
Polish after stripping/cleaning
Platers don’t like secondhand pipes as they can leave contaminants in their tanks that may spoil other work. You can try to bullshit them that it’s clean but if it causes other jobs to stuff up you will have to face them when you pick up your pipe.
Some platers will do a secondhand pipe but they will leave it in their cleaning tanks longer so they will charge accordingly. They may try to fob you off at first as they don’t like these jobs but a bit of pleading may make them fold.
Platers are another dying industry, too many flaming hoops for them to jump through these days.
Offline ITDOG
« Reply #8 on: November 04, 2015, 12:33:48 am »
yeah try pipeking he does a pretty good job...near Armadale, does a works type finish oiled/blued removes all carbon and dents around $150-175 all up...check his pics on Facebook
Offline ITDOG
« Reply #9 on: November 04, 2015, 12:38:01 am »
« Reply #10 on: November 04, 2015, 12:44:26 am »
ITDOG - can't find him on FB?
Offline ITDOG
« Reply #11 on: November 04, 2015, 12:47:32 am »
pipeking repairs ???.....tredinick I think his surname is
Offline ITDOG
« Reply #12 on: November 04, 2015, 12:48:42 am »
Offline tymes
« Reply #13 on: November 04, 2015, 02:42:49 am »
Besides industrial hard chrome there are none left in the Illawarra any more.
Would hot tanking clean the pipe out?
« Reply #14 on: November 04, 2015, 03:34:21 am »
thanks ITDOG - found him now - thanks for the link  ;D
