Author Topic: Johnny on the spot.  (Read 9390 times)
Offline pecrazy
Johnny on the spot.
« on: October 11, 2015, 09:39:24 am »
Found this listed on Facebook, only just around the corner and $100. Bloke said it just stopped, while loading it he said it kicks back while trying to start it, I knew straight away the timing was off. Cam chain is that worn that I was able to slip it back the 2 teeth and it fired straight up. Top end rebuild and a good cosmetic tidy up and she will be sweet.
Offline smed
Re: Johnny on the spot.
« Reply #1 on: October 11, 2015, 05:31:32 pm »
Sweet score 8) 8) 8) 8)
Offline Bullet
« Reply #2 on: October 11, 2015, 05:48:02 pm »
That's a bargain, sometimes you just have a win.
Cheers Mick
Offline jimson
  • Sanctuary point N.S.W
« Reply #3 on: October 11, 2015, 06:28:14 pm »
Cool score & a local pick up  8) jimson
« Reply #4 on: October 11, 2015, 08:44:35 pm »
Vinduro eligible too
Offline pecrazy
« Reply #5 on: October 12, 2015, 06:33:28 am »
99 model, vinduro around here is pre 90's I believe. Still looking forward to getting it back to it's forma glory.
Offline OverTheHill
« Reply #6 on: October 12, 2015, 06:41:40 am »
good one!!. Talking 'pecrazy'--i have one of those motors in a pe250.
Offline pecrazy
« Reply #7 on: October 12, 2015, 07:40:26 am »
A local guy has an XL motor in a pe400 frame, used what he could back in the day, still has it but won't sell it.
Offline Andrew L
« Reply #8 on: October 12, 2015, 08:24:37 am »
All 200 xrs are considered eligible as flow on's if I remember right ( in Victoria anyway )
Offline Tex
« Reply #9 on: October 12, 2015, 09:34:44 am »
Lucky find at that price!
« Reply #10 on: October 12, 2015, 11:21:01 am »
all 200's are eligble for VERI events ..drum brakes, same config as 1984
Offline pecrazy
« Reply #11 on: November 15, 2015, 07:50:52 pm »
Got a bit done, think I've spent way too much time on it and I definetly have spent way too much money. 2 pac on the frame, rebuilt the top end of the motor, serviced and installed new seals in the forks, head stem bearings, chain and sprockets, suspension bearings either cleaned and greased or replaced.
« Reply #12 on: November 15, 2015, 09:00:08 pm »
should have just wacked a cam chain in and flogged it for 1500....after all that work you might get 2000 for it??
Offline pecrazy
« Reply #13 on: November 15, 2015, 09:03:58 pm »
Yes I know, not that a 99 xr200 will ever be collectable, should have flicked it and spent the money on my PE. But it will be a nice little bike when it's done, was a pretty easy resto, the PE can wait it's turn.
« Reply #14 on: November 15, 2015, 09:06:04 pm »
seriously good little bike, so versatile and so much fun. wheelies? chain a Labrador too it and it will be pulling 200 metre monos in 5 minutes....
