Marque Remarks
Honda
Johnny on the spot.
All
Topic: Johnny on the spot. (Read 9385 times)
pecrazy
B-Grade
Johnny on the spot.
October 11, 2015, 09:39:24 am »
Found this listed on Facebook, only just around the corner and $100. Bloke said it just stopped, while loading it he said it kicks back while trying to start it, I knew straight away the timing was off. Cam chain is that worn that I was able to slip it back the 2 teeth and it fired straight up. Top end rebuild and a good cosmetic tidy up and she will be sweet.
smed
Re: Johnny on the spot.
October 11, 2015, 05:31:32 pm »
Sweet score
Bullet
C-Grade
October 11, 2015, 05:48:02 pm »
That's a bargain, sometimes you just have a win.
Cheers Mick
jimson
Sanctuary point N.S.W
October 11, 2015, 06:28:14 pm »
Cool score & a local pick up
jimson
80-85 husky
Reply #4 on:
October 11, 2015, 08:44:35 pm »
Vinduro eligible too
pecrazy
B-Grade
Reply #5 on:
October 12, 2015, 06:33:28 am »
99 model, vinduro around here is pre 90's I believe. Still looking forward to getting it back to it's forma glory.
OverTheHill
Reply #6 on:
October 12, 2015, 06:41:40 am »
good one!!. Talking 'pecrazy'--i have one of those motors in a pe250.
pecrazy
B-Grade
Reply #7 on:
October 12, 2015, 07:40:26 am »
A local guy has an XL motor in a pe400 frame, used what he could back in the day, still has it but won't sell it.
Andrew L
Reply #8 on:
October 12, 2015, 08:24:37 am »
All 200 xrs are considered eligible as flow on's if I remember right ( in Victoria anyway )
Reply #9 on:
October 12, 2015, 09:34:44 am »
Lucky find at that price!
80-85 husky
Reply #10 on:
October 12, 2015, 11:21:01 am »
all 200's are eligble for VERI events ..drum brakes, same config as 1984
pecrazy
B-Grade
Reply #11 on:
November 15, 2015, 07:50:52 pm »
Got a bit done, think I've spent way too much time on it and I definetly have spent way too much money. 2 pac on the frame, rebuilt the top end of the motor, serviced and installed new seals in the forks, head stem bearings, chain and sprockets, suspension bearings either cleaned and greased or replaced.
80-85 husky
Reply #12 on:
November 15, 2015, 09:00:08 pm »
should have just wacked a cam chain in and flogged it for 1500....after all that work you might get 2000 for it??
pecrazy
B-Grade
Reply #13 on:
November 15, 2015, 09:03:58 pm »
Yes I know, not that a 99 xr200 will ever be collectable, should have flicked it and spent the money on my PE. But it will be a nice little bike when it's done, was a pretty easy resto, the PE can wait it's turn.
80-85 husky
Reply #14 on:
November 15, 2015, 09:06:04 pm »
seriously good little bike, so versatile and so much fun. wheelies? chain a Labrador too it and it will be pulling 200 metre monos in 5 minutes....
All
Marque Remarks
Honda
Johnny on the spot.
