Marque Remarks
Kawasaki
KLX con rod kit
Topic: KLX con rod kit (Read 4618 times)
The Stroker
C-Grade
KLX con rod kit
September 02, 2015, 09:59:29 am »
Still chasing a klx conrod kit. Ie rod, pin and big end bearing. Help please
Cheers Brett
cyclegod
Sunny PERTH W.A
Re: KLX con rod kit
September 02, 2015, 10:10:16 am »
http://www.ebay.com.au/itm/KAWASAKI-KL250-KLT250-KZ250-1982-1984-CONNECTING-ROD-NOS-JAPAN-13044-5026-/181639955354?hash=item2a4a95c39a
http://www.ebay.com.au/itm/GENUINE-KAWASAKI-CON-ROD-KIT-KLT250-82-85-KL250-83-84-KZ250-83-OEM-13044-5026-/221255160982?hash=item3383d5d496
Ban BLACK rims NOW
sleepy
Re: KLX con rod kit
September 02, 2015, 10:12:21 am »
Do you have any dimension as there may be something else that could or be made to fit if the original is no longer available.
cyclegod
Sunny PERTH W.A
Re: KLX con rod kit
September 02, 2015, 10:29:19 am »
Here is the only place I have found that has stock
https://translate.google.com/translate?hl=en&sl=el&u=http://www.car.gr/parts/view/6145824/%3Flang%3Den&prev=search
Ban BLACK rims NOW
cyclegod
Sunny PERTH W.A
Re: KLX con rod kit
Reply #4 on:
September 02, 2015, 10:32:24 am »
This one gives specs...
http://www.ebay.com.au/itm/KAWASAKI-KZ-KLT-250-KZ250-KLT250-CRANKSHAFT-CONNECTING-ROD-KIT-/230302572068?hash=item359f1a5e24
Ban BLACK rims NOW
sleepy
Re: KLX con rod kit
Reply #5 on:
September 02, 2015, 12:33:25 pm »
There is a KTM rod that is 119mm long 32mm pin and a 20mm small end. Would need to re-bush the small end, bore the crank to 32mm and fit a 1mm spacer under the barrel. All possible if you can't get anymore kits.
Marque Remarks
Kawasaki
KLX con rod kit
