Author Topic: KLX con rod kit  (Read 4295 times)
Offline The Stroker
KLX con rod kit
« on: September 02, 2015, 09:59:29 am »
Still chasing a klx conrod kit. Ie rod, pin and big end bearing. Help please
Cheers Brett
Re: KLX con rod kit
« Reply #2 on: September 02, 2015, 10:12:21 am »
Do you have any dimension as there may be something else that could or be made to fit if the original is no longer available.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: KLX con rod kit
« Reply #3 on: September 02, 2015, 10:29:19 am »
Ban BLACK rims NOW
Offline cyclegod
  • Sunny PERTH W.A
Ban BLACK rims NOW
Re: KLX con rod kit
« Reply #5 on: September 02, 2015, 12:33:25 pm »
There is a KTM rod that is 119mm long 32mm pin and a 20mm small end. Would need to re-bush the small end, bore the crank to 32mm and fit a 1mm spacer under the barrel. All possible if you can't get anymore kits.
