Author Topic: Shocky bush suppliers ?  (Read 9497 times)
Offline Mike52
  • 81 KTM 125 LC
« on: August 07, 2015, 09:13:32 am »
Anyone know who does rubber shocky bushes for my PE 250c.
They look to be 24mm od  , 22mm wide with a 10mm id steel tube in them.
Mike
« Last Edit: August 07, 2015, 01:41:31 pm by Mike52 »
Offline Brian Watson
  • First Penton in OZ
Re: Shocky bush suppliers ?
« Reply #1 on: August 07, 2015, 10:50:46 am »
Walter will have them.. buy from an Australian supplier..
« Reply #2 on: August 07, 2015, 02:08:41 pm »
but he still gets them made overseas :)
« Reply #3 on: August 07, 2015, 03:25:05 pm »
That may be the case Kerry.. but at least some of the money spent is here in OZ.. much rather support the locals.. wouldn't you..??
Offline OverTheHill
« Reply #4 on: August 07, 2015, 07:21:53 pm »
How about honda rear sprocket rubber/steel bonded mounts, xr200 or just about any small honda. Just bought some from china so i'll have a measure up. Might be 9mm id not 10 but a sharp drill might fix it without unbonding. thought they were 24 od but might be wrong, could be 25. Update [30 seconds later lol] Ebayed & 24 OD--9.3 ID & 21 Wide, i'd guess the 21 is across the centre bit if it's a bit wider than outer bit where it presses in. Anyway-just an option possibly [& cheap]. Question though--did the PE's have [whatdaya call them] heim joints or uniball joints on the left to allow for misalignment due to the offset on the left for the wide QD wheel?. Sorry if i'm talking crap--i'm mostly yamaha but have an XR200 in a twin shock PE250 frame. Well. till it broke the gudgeon eye out of the rod oneday & f"£&'n totaly destroyed it [stop laughing], now it's just a smokey old 185 as a fill in. Hope that info helps but i'm real good at confusing things. Cheers.
Offline DR500
« Reply #5 on: August 07, 2015, 07:28:33 pm »
« Reply #6 on: August 07, 2015, 08:00:39 pm »
You might want to check the 24mm measurement. The RM/PE shocks from that era that i ahve seen had 23mm OD
Try this part for KYB/HPG Snow/ATV shocks
http://www.deycore.com/deycore-shock-parts/kyb-hpg-shock-parts/kyb-hpg-bushings/eyelet-bushing-id-395-sleeve-length-1-178-overall-length-980.html
If you do need 24mm OD then you coul use this
http://www.pivotworks.com/ProductInfo.aspx?item_id=52656
10x24 spherical bearing
« Last Edit: August 08, 2015, 07:23:29 pm by LWC82PE »
Offline Mike52
  • 81 KTM 125 LC
« Reply #7 on: August 08, 2015, 07:13:55 pm »
I must have the wrong or non original shocks fitted although they look like the originals in
http://www.alpha-sports.com/suzuki_parts.htm
Mine are hourglass shaped od  , rubber with no outer shell and a steel central tube
Sort of like a car shock rubber.
Mike
« Last Edit: August 08, 2015, 07:15:45 pm by Mike52 »
« Reply #8 on: August 08, 2015, 07:21:58 pm »
All suzuki/KYB shocks have the Suzuki part number stamped on the bodies near the top. What are the part numbers on yours?
