Author Topic: Suzuki RM370B  (Read 12647 times)
Suzuki RM370B
« on: July 30, 2015, 06:27:50 pm »
Gents - what volume oil for the forks - standard I think??? - on a 77 RM370B please?
ta
Rossco
Offline davidh
Re: Suzuki RM370B
« Reply #1 on: July 30, 2015, 06:57:00 pm »
250/370A 245 cc 250/370B 247 cc
Re: Suzuki RM370B
« Reply #2 on: July 30, 2015, 07:30:09 pm »
thank you very much
Re: Suzuki RM370B
« Reply #3 on: July 30, 2015, 09:30:05 pm »
David - you wouldn't also know the gearbox oil capacity required for just a change would you?  Ie not split the cases etc?
ta
Rossco
Offline davidh
Re: Suzuki RM370B
« Reply #4 on: July 30, 2015, 10:50:40 pm »
The 370 takes 1000 for a change and 1100 from dry .
Re: Suzuki RM370B
« Reply #5 on: July 31, 2015, 10:33:22 am »
thank you  ;D
Re: Suzuki RM370B
« Reply #6 on: August 01, 2015, 04:52:25 pm »
next question - as doing a tidy up on this RM.
In pulling bits and pieces off the bike for some minor resto and repair work I have found it appears the kill switch is not connected although the two wires are "end" loose under the tank.  It doesn't appear there is anywhere the wires have pulled from as there is only one connector not hooked up underneath?  Any suggestions?  I did a check on spark and still have spark so wondering whether it has been connected at all as I know some guys do or do the 2 wires feed into the one connector?  Bit ambiguous questioning I know!
Rossco
Offline smed
Re: Suzuki RM370B
« Reply #7 on: August 01, 2015, 05:07:49 pm »
Earth wire onto coil mount or frame Rosco?
Re: Suzuki RM370B
« Reply #8 on: August 01, 2015, 05:12:01 pm »
doesn't look like it.  Bit grubby underneath so hard to see if they have pulled from anywhere but doubtful.  But will have another look.
Offline Tossa
Re: Suzuki RM370B
« Reply #9 on: August 01, 2015, 05:34:35 pm »
nana nap please Rossco, or I'll tell Vicki!!!!
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Re: Suzuki RM370B
« Reply #10 on: August 01, 2015, 05:40:33 pm »
Vicki isn't here - that's why I am on the bike.  Front end finished Baz.
Offline Tossa
Re: Suzuki RM370B
« Reply #11 on: August 01, 2015, 08:36:44 pm »
behave yourself we have 5 weeks!!
Offline FourstrokeForever
  • AKA Mark H #35 VCM
Re: Suzuki RM370B
« Reply #12 on: August 02, 2015, 08:59:36 am »
Rosco, 1 wire should be earthed to metal and the other wire to coil (there should be a wire from coil to connect to)
Re: Suzuki RM370B
« Reply #13 on: August 02, 2015, 09:41:10 am »
RM 370 has a one wire kill switch (round metal with red button) as standard, goes to the coil. You must have an after market one on your bike. You can buy reproduction original style switches from any bike shop.
Re: Suzuki RM370B
« Reply #14 on: August 02, 2015, 12:40:07 pm »
thanks guys - yes K saw that when I went looking and therefore can't see where these wires have "pulled" from which makes me wonder if they were ever hooked up.  Shall have a play and if does not work with earthing and connecting will try and get a 1 wire one.
thanks
Rossco
