Marque Remarks
Suzuki
Suzuki RM370B
All
Topic: Suzuki RM370B (Read 12628 times)
Rossvickicampbell
Suzuki RM370B
July 30, 2015, 06:27:50 pm »
Gents - what volume oil for the forks - standard I think??? - on a 77 RM370B please?
ta
Rossco
davidh
Novice
Re: Suzuki RM370B
July 30, 2015, 06:57:00 pm »
250/370A 245 cc 250/370B 247 cc
Rossvickicampbell
Re: Suzuki RM370B
July 30, 2015, 07:30:09 pm »
thank you very much
Rossvickicampbell
Re: Suzuki RM370B
July 30, 2015, 09:30:05 pm »
David - you wouldn't also know the gearbox oil capacity required for just a change would you? Ie not split the cases etc?
ta
Rossco
davidh
Novice
Re: Suzuki RM370B
Reply #4 on:
July 30, 2015, 10:50:40 pm »
The 370 takes 1000 for a change and 1100 from dry .
Rossvickicampbell
Re: Suzuki RM370B
Reply #5 on:
July 31, 2015, 10:33:22 am »
thank you
Rossvickicampbell
Re: Suzuki RM370B
Reply #6 on:
August 01, 2015, 04:52:25 pm »
next question - as doing a tidy up on this RM.
In pulling bits and pieces off the bike for some minor resto and repair work I have found it appears the kill switch is not connected although the two wires are "end" loose under the tank. It doesn't appear there is anywhere the wires have pulled from as there is only one connector not hooked up underneath? Any suggestions? I did a check on spark and still have spark so wondering whether it has been connected at all as I know some guys do or do the 2 wires feed into the one connector? Bit ambiguous questioning I know!
Rossco
smed
Re: Suzuki RM370B
Reply #7 on:
August 01, 2015, 05:07:49 pm »
Earth wire onto coil mount or frame Rosco?
Rossvickicampbell
Re: Suzuki RM370B
Reply #8 on:
August 01, 2015, 05:12:01 pm »
doesn't look like it. Bit grubby underneath so hard to see if they have pulled from anywhere but doubtful. But will have another look.
Tossa
Re: Suzuki RM370B
Reply #9 on:
August 01, 2015, 05:34:35 pm »
nana nap please Rossco, or I'll tell Vicki!!!!
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Rossvickicampbell
Re: Suzuki RM370B
Reply #10 on:
August 01, 2015, 05:40:33 pm »
Vicki isn't here - that's why I am on the bike. Front end finished Baz.
Tossa
Re: Suzuki RM370B
Reply #11 on:
August 01, 2015, 08:36:44 pm »
behave yourself we have 5 weeks!!
FourstrokeForever
AKA Mark H #35 VCM
Re: Suzuki RM370B
Reply #12 on:
August 02, 2015, 08:59:36 am »
Rosco, 1 wire should be earthed to metal and the other wire to coil (there should be a wire from coil to connect to)
bigk
Kangaroo Flat Victoria
Re: Suzuki RM370B
Reply #13 on:
August 02, 2015, 09:41:10 am »
RM 370 has a one wire kill switch (round metal with red button) as standard, goes to the coil. You must have an after market one on your bike. You can buy reproduction original style switches from any bike shop.
Rossvickicampbell
Re: Suzuki RM370B
Reply #14 on:
August 02, 2015, 12:40:07 pm »
thanks guys - yes K saw that when I went looking and therefore can't see where these wires have "pulled" from which makes me wonder if they were ever hooked up. Shall have a play and if does not work with earthing and connecting will try and get a 1 wire one.
thanks
Rossco
All
Marque Remarks
Suzuki
Suzuki RM370B
