Author Topic: Something we all should have in the shed  (Read 26670 times)
« on: May 22, 2015, 10:28:24 pm »
Offline Moto
Re: Something we all should have in the shed
« Reply #1 on: May 22, 2015, 10:32:44 pm »
Wire Buffing wheel.Makes all your dirty rusty bits new again.
Offline Daryl Jones
    • Old Bike World
« Reply #2 on: May 22, 2015, 11:16:06 pm »
Plenty of Time!
Charles Kettering.
Offline SON
« Reply #3 on: May 23, 2015, 04:21:15 am »
TORQUE WRENCH
Lozza wins!
It's the first question I ask any Mechanic or so called Mechanic who walks in with a Resume
What's the torque setting on the sump plug of a 450 Motocrosser ?
What brand ? doesn't matter ?
Make a guess ?
What's your guess ?
Or a 250 2 smoke?
« Reply #4 on: May 23, 2015, 07:07:22 am »
Son .... till it strips then back it off  a 1/4 of a turn.  When do I start   ;D
Offline Doc
« Reply #5 on: May 23, 2015, 08:10:05 am »
 Calibrated click method
1 click (elbow) - 40f/lbs
2 clicks (elbow and wrist) -  60f/lbs
As above with torn bicep - 80f/lbs
As above with shoulder dislocation - 100f/lbs
Burred knuckles you've gone too far!
Offline crossedup2
  • Never enough shed time.....
« Reply #6 on: May 23, 2015, 04:44:35 pm »
Two young apprentices on the end of a 3/4 drive socket - 2" nut and 2 metres pipe extension on a bobcat gear box drive nut to undo. Wouldn't move!
Boss thought we were whimps! and had a go himself. No luck! Started using all different methods he had up his (older) sleeve and still no luck. So he cut the nut off!
Didn't have the heart at that point to tell him the manual said that it had to be torqued up to over 250ft/lbs.
A week later and about $500 in parts to fix bosses handy work and $500 on a torque multiplying tool and some free choice words, one apprentice had the jobs done.
It was known for quite a while that two young barred up apprentices could F#@K the boss every time. (The joke lasted for years!) ;) ;) ;)
Peter B
Offline TTezza
« Reply #7 on: May 23, 2015, 05:23:44 pm »
« Reply #8 on: May 23, 2015, 05:27:41 pm »
Offline Momus
« Reply #9 on: May 23, 2015, 06:16:15 pm »
Multi tool only counts if you display something you made using it...
My suggestion is a couple of humble 100 ml veterinarians syringes with a clear flex tube attachment.
Invaluable for decanting and adding any workshop fluid.  Mine get used as everything from a burette for compression ratio checks to calibrated fork oil top ups/reductions to priming grumpy starting 2 strokes.
If you love it, lube it.
« Reply #10 on: May 23, 2015, 08:12:06 pm »
a laptop with internet connection to:
1. look up how to videos
2. post here
3 watch "idiots on motorbikes" videos
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #11 on: May 24, 2015, 08:25:03 am »
Daisy Duke to do all the shitty cleaning and polishing jobs ( oh, really, ok then) while I take care of the important stuff like check the beer fridge is stocked....
Offline TooFastTim
« Reply #12 on: May 24, 2015, 08:35:42 am »
TORQUE WRENCH
All that effort and then he sticks a pair of vice grips on the end  :o
Offline fred99999au
« Reply #13 on: May 24, 2015, 06:16:38 pm »
They were calibrated vice grips.
Offline g465b
« Reply #14 on: May 24, 2015, 06:49:06 pm »
a well organised area for all those spare parts,that may come in handy one day....[/URL][/img]
