Author Topic: XL 350 center port gearbox  (Read 1418 times)
Offline Rodsmetal
« on: April 20, 2015, 05:42:05 pm »
Hi All
I have a older 350  side port engine with a 420 kit  hi comp  , slips out in 5th gear ,was told the  center port engine had a better/upgrade gearbox .
Or some advice knowledge  on the known problem, bevel cut gear  dogs?  etc .
Rod
ride on
Offline FourstrokeForever
  • AKA Mark H #35 VCM
Re: XL 350 center port gearbox
« Reply #1 on: April 20, 2015, 10:29:03 pm »
Back cut the problem dogs on 5th and 3rd gears. Also, speed up the clutch gears. Make sure you run a cush drive rear hub.
