Author Topic: Bearing pullers  (Read 11732 times)
Offline FAT-TOY
Bearing pullers
« on: April 11, 2015, 07:11:36 pm »
  Need to buy a set of bearing pullers.  These are cheap and I will only use them from time to time, so anyone used them, are they ok or are they shit.
                                      Zane
Everyday I find one more name to add to the list of people who piss me off.
Offline mick25
  • Hunter valley NSW
Re: Bearing pullers
« Reply #1 on: April 11, 2015, 07:37:40 pm »
I have a sett very close to that zane
I got it through ballards , one of mine broke butt .
I went down to Bunnings and got a concrete dyna bolt that flares out when tighted this can be used to remove bearings , I use the dyna bolt now to make up for the broken one in the kit I have .
Re: Bearing pullers
« Reply #2 on: April 12, 2015, 12:35:03 am »
Very handy for wheel bearings. I have even used the mandrels to hold items while machining
Offline Blackjack
Re: Bearing pullers
« Reply #3 on: April 13, 2015, 11:45:37 am »
Torpedo7 use dto be the best place to by bearing puller kits from but I just checked their website and can no longer see them listed? If you find somewhere else lettuce know......
Offline fred99999au
Re: Bearing pullers
« Reply #4 on: April 13, 2015, 02:49:43 pm »
They are a good thing for the price, and indispensable if you need them, but I am not too sure of the longevity of them.
I think there is a fair amount of Chineseium in them.
Offline brucey
Re: Bearing pullers
« Reply #5 on: April 13, 2015, 04:27:27 pm »
http://www.tridon.com.au/products/Bikeservice
This range of tools is pretty good ive used them nick into your local bursons / repco etc and they will get them for you
Bruce
Re: Bearing pullers
« Reply #6 on: April 13, 2015, 05:16:50 pm »
MCS have them
http://mcsonline.com.au/catalogue
but now i need a 22mm one as i got some 22mm ID swingarm bearings but the 20mm puller is too small and 25mm is too big.
Offline robcan
Re: Bearing pullers
« Reply #7 on: April 13, 2015, 05:57:58 pm »
What about a good quality one I asked  snap on sue in canberra a while ago / looked at me as if I had two heads
Offline fred99999au
Re: Bearing pullers
« Reply #8 on: April 13, 2015, 08:49:32 pm »
You'd need a second mortgage to afford a Snap On one I reckon.
Offline Canam370
Re: Bearing pullers
« Reply #9 on: April 13, 2015, 09:30:04 pm »
I've not had any drama's with the MCS blind bearing pullers. They also make a wheel bearing removal kit which has had some successful enthusiastic use. I wouldn't try using the blind bearing pullers on wheel bearings or larger case bearings - use the appropriate tool for the job, sometimes add a bit of heat to help, and they will work fine.
Offline FAT-TOY
Re: Bearing pullers
« Reply #10 on: April 13, 2015, 10:07:05 pm »
   I purchased that set today off ebay, I think they will be worth a try, only cost $30 plus around $10 postage.
                                                     Zane
Offline grouty
Re: Bearing pullers
« Reply #11 on: April 14, 2015, 05:37:39 pm »
I have had one of these sets for a few years now.
Good value for money, but be aware they are made from case hardened cheese !
The tips of the pullers are not that hard and will round off easily.
Thumpers Rule !
Re: Bearing pullers
« Reply #12 on: April 14, 2015, 07:42:34 pm »
                                                     Zane
even if you only use it a few times $40 is not much investment considering labour at a bike shop is much more for 1 Hour!
Re: Bearing pullers
« Reply #13 on: August 03, 2015, 07:14:24 pm »
This isn't a puller set, but a wheel bearing knockerer outerer set.
I haven't tried it yet, just arrived. Logical concept though and I cant see why it wont be my best Motorcycle wheel bearing remover set EVER to date.
The intention is to take unnecessary stress of my more expensive expanding collet puller sets and save them for blind bearings etc, as originally intended. I don't see ever wearing this set out.
All motorcycle wheel bearing sizes covered too 8)
« Last Edit: August 03, 2015, 07:45:59 pm by Mick D »
Offline fred99999au
Re: Bearing pullers
« Reply #14 on: August 03, 2015, 10:01:20 pm »
They also do blind bearings in cases like Yamaha mainshaft bearings (i.e the ones not on the clutch end).
And Clutch shaft bearings.
Which is why I bought one.
Also took it to a mate for a job on his KDX and his boss marvelled at the technology. They have a very good engimineering workshop. Wont buy one though because someone will knock it off.
