Author Topic: PVL - intermittent spark  (Read 20905 times)
« on: March 07, 2015, 01:46:50 pm »
Gents - PVL - hooked up to YZ360B - no spark issues before shutting down for overhaul.  Motor has been out since August last year and bike sitting in shed since.  Everything back in OK but won't start - gets close but no first prize.  Have checked fuel, changed spark plugs but no go - fuel on plug.  On doing the old remove plug and check against head trick found spark is intermittent at best but thought this might be due to trying to turn over by hand whilst watching plug.  Have checked external connections and cleaned etc but still no go.  Any thoughts on something I may have missed?  Have not had this happen before?
Loz?
ta guys
Rossco
Offline Slow Pete
Re: PVL - intermittent spark
« Reply #1 on: March 07, 2015, 01:50:47 pm »
Very similar to my 81RM.  Try putting a multi meter on the magneto/stator/coil the specs will be in your manual
Pete
Past owner of.  Bultaco 125,  Suzuki RM250A, RM125C, RM125T, RM400N, RM125X, Maico AW250 1977.   Presently 81 RM250X , 87 RM125H , 86 RM250G & 81 RM125X.   Current projects 80 RM400T & 78 RM125C
« Reply #2 on: March 07, 2015, 03:13:13 pm »
ground the plug properly and turn the flywheel with a drill in reverse. Report finding.
« Reply #3 on: March 07, 2015, 04:16:50 pm »
ground the stator ok to the cases? got to be something not reassembled right....ol mate did a xr up and kikety kickety kick %^&^%$$# tore it back down and checked all...more kicking no going $#@#%%% another partial teardown to check cam timing etc... then noticed swapped wire on second coil..1 kick....@#$#$%^^
Offline alexbrown64
« Reply #4 on: March 07, 2015, 04:58:57 pm »
You mentioned overhaul?  Was the frame re-painted.  Engine painted?  May need to grind some paint from engine mounting points on engine and frame, and where the coil bolts on.  PVL recommends an iridium style plug for stronger sparking, especially when checking spark by hand cranking. I take it you have rechecked timing and all wiring/earths, swapped plugs etc..
I just rebuilt my bike and put the PVL stator and coil on, did timing etc on the bench.  Made sure ALL of the above were correct and she started 4th kick from a full rebuild.
Good luck and keep us posted on results..
Alex
« Reply #5 on: March 07, 2015, 05:00:30 pm »
Rossco  its stuffed , sell it to me you know I collect old scrap . Iain
« Reply #6 on: March 07, 2015, 07:34:19 pm »
thanks everyone - shall play some more - especially Iain for his thoughts  ;D
Offline martian170
« Reply #7 on: March 07, 2015, 08:15:28 pm »
Capacitor
« Reply #8 on: March 07, 2015, 11:48:07 pm »
whats the capacity? will that fix the capacitor?
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #9 on: March 08, 2015, 10:00:20 am »
I had the same problem with a PVL I had on my B50. All was good until the day it decided to play hard to start. Changed the plug and checked spark. Even at full kick speed the spark was very weak and intermittent. The ignition slowly got worse until the day it wouldn't even push start. I gave up on the PVL and bought an Electrex World ignition and now I'm back to easy starting and a bike that is much more responsive.
Offline Tossa
« Reply #10 on: March 08, 2015, 11:18:08 am »
which is more than can be said of the rider!!
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Offline martian170
« Reply #11 on: March 08, 2015, 12:02:10 pm »
Capacitor is the thing that stores electrical energy and releases it when required ie CDI = capacitor discharge ignition. Hence when people say you should never kick Ya bike over without the plug being earthed is because the capacitor cannot discharge, it heats up and pops new ones are about $3 from RS spares
Offline bazza
« Reply #12 on: March 08, 2015, 01:31:12 pm »
Electrix world ignition on the B44, love it.
Embrace patina
« Reply #13 on: March 09, 2015, 09:12:18 am »
Thanks for the recognition Bazza...... I think  ::) ::) ::)
Offline dkupf
  • Kinka Beach Qld
« Reply #14 on: March 22, 2015, 10:38:57 am »
I had a similar problem with a PVL on a Maico after months of looking I found that the flywheel had rubbed through the wires behind the mounting plate.
