Author Topic: 84 ktm 250 clutch plates  (Read 6851 times)
Offline gra1961
« on: February 09, 2015, 08:35:55 am »
am putting together a 544 type 250 motor at the moment ,have a few parts donor motors and the steel clutch plate are all 1mm thick (dont appear to be worn) but parts calaloge have them listed as 1.5 mm thick?any clues?
Offline supermotomc
Re: 84 ktm 250 clutch plates
« Reply #1 on: February 11, 2015, 10:09:32 am »
quote clutch group base disc1x 2.35 fibre   7 x Sintered 2.0  8 x Steel plate 1.4
Offline gra1961
« Reply #2 on: February 11, 2015, 05:53:41 pm »
i guess i will be going 8 and 9 then
Offline oz555ktm
« Reply #3 on: February 11, 2015, 06:34:48 pm »
   Place 2 steels together to make the space ..
  Dennis
  if you are have trouble call me ....
And Please forgive me as I cant Spell for Shit ...
And I have very Bad Gramer ...too I been told ......
Offline supermotomc
« Reply #4 on: February 12, 2015, 01:00:06 pm »
importantly ensure that ever plate is the right way round ie Same way ! Have you drilled the inner hub for more oil circulation ?
« Last Edit: February 12, 2015, 01:01:47 pm by supermotomc »
Offline gra1961
« Reply #5 on: February 13, 2015, 07:29:57 am »
havnt had any probs with how the clutch works with the other 250's (543 & 544) i have. just wondering why i have so many of these 1mm steel plates and not the 1.4 mm ones.i see horvaths have 1mm & 1.4 mm listed for these types of motors.
Offline supermotomc
« Reply #6 on: February 13, 2015, 11:50:30 am »
Just checked some clutches here yep their 1.4 so 8x1.4 is 11.2 we did add two steels as the clutches wore but you have to make up 3.2 mm so in theory you need 3 more 1mm  id get some new steels if i were you. you have to get the basic stack right remember too if the stack is too much when you disengage the outer pressure plate may rotate and damage will result YOU need 27.55mm  all up
Offline gra1961
« Reply #7 on: February 22, 2015, 07:49:32 pm »
went thru my other parts manuals and they do run 1mm steel plates and it is just one extra of each
