Marque Remarks
KTM
84 ktm 250 clutch plates
Topic: 84 ktm 250 clutch plates (Read 6850 times)
gra1961
A-Grade
February 09, 2015, 08:35:55 am »
am putting together a 544 type 250 motor at the moment ,have a few parts donor motors and the steel clutch plate are all 1mm thick (dont appear to be worn) but parts calaloge have them listed as 1.5 mm thick?any clues?
supermotomc
C-Grade
SWM ktm, dealer mechanic 1977-1995
Re: 84 ktm 250 clutch plates
February 11, 2015, 10:09:32 am »
quote clutch group base disc1x 2.35 fibre 7 x Sintered 2.0 8 x Steel plate 1.4
gra1961
A-Grade
February 11, 2015, 05:53:41 pm »
i guess i will be going 8 and 9 then
oz555ktm
February 11, 2015, 06:34:48 pm »
Place 2 steels together to make the space ..
Dennis
if you are have trouble call me ....
supermotomc
C-Grade
Reply #4 on:
February 12, 2015, 01:00:06 pm »
importantly ensure that ever plate is the right way round ie Same way ! Have you drilled the inner hub for more oil circulation ?
Last Edit: February 12, 2015, 01:01:47 pm by supermotomc
gra1961
A-Grade
Reply #5 on:
February 13, 2015, 07:29:57 am »
havnt had any probs with how the clutch works with the other 250's (543 & 544) i have. just wondering why i have so many of these 1mm steel plates and not the 1.4 mm ones.i see horvaths have 1mm & 1.4 mm listed for these types of motors.
supermotomc
C-Grade
Reply #6 on:
February 13, 2015, 11:50:30 am »
Just checked some clutches here yep their 1.4 so 8x1.4 is 11.2 we did add two steels as the clutches wore but you have to make up 3.2 mm so in theory you need 3 more 1mm id get some new steels if i were you. you have to get the basic stack right remember too if the stack is too much when you disengage the outer pressure plate may rotate and damage will result YOU need 27.55mm all up
gra1961
A-Grade
Reply #7 on:
February 22, 2015, 07:49:32 pm »
went thru my other parts manuals and they do run 1mm steel plates and it is just one extra of each
Marque Remarks
KTM
