Author Topic: 1980 PE250 Con Rod  (Read 6983 times)
Offline BAHNZY
1980 PE250 Con Rod
« on: July 13, 2008, 09:30:36 pm »
Sometime back when i was looking for a PE175 conrod (aftermarket) someone on this forum did a cross reference check and found that it fitted about 5 or so other models. These models were listed in the aftermarket catalogues, hence an aftermarket conrod was avalaible, even though the specific bike, in the case a 80 PE250, wasnt. Is anyone able to do this X-reference for me please?
Rod (BAHNZY) Bahn
Offline gorby
Re: 1980 PE250 Con Rod
« Reply #1 on: July 14, 2008, 12:07:44 am »
hello bahnsy,
                the guys at BBImporters cross referenced a Pro-X skidoo rod to fit my brothers 81 PE250
They don't deal direct but most shops can source them.
« Reply #2 on: July 14, 2008, 09:38:28 am »
Hello Bahnsy,
ProX 03.6642 is the rod kit to use, '93-'97 Skidoo, but the pin is too short. You also need to buy an 06.2458 big end pin. It fits RM/PE and will fit CR250M as well. I'm sure you know a couple of shops who can get it from BBI for you.
Offline suzuki 400
« Reply #3 on: July 15, 2008, 11:20:17 pm »
i got mine from alpha,s with new thrust washers  correct suzuki part numbers and check with the suzuki dealer it may be available still also suzuki pe site in the uk has them it,s the pe400 conrod i need  :-[ and can,t find new had to settle for new bearing and thrust washers ,it will be a 20.1 mix thru this to keep it allive
« Reply #4 on: July 16, 2008, 12:05:08 pm »
Yes it's the 400 rod that is NO LONGER available .
Re: RM/PE250 Con Rod
« Reply #5 on: April 28, 2009, 07:57:24 pm »
so this is the rod to use for the RM/PE 250
ProX 03.6642 for the '93-'97 Skidoo
Pro X say its for a Skidoo 599 triple
can anyone elaborate on that model? is there a model name?
i am trying to find a rod for that model here https://www.hotrodsproducts.com in Hot Rods brand
i would like to compare value/quality/price etc.
« Last Edit: April 28, 2009, 08:07:26 pm by LWC3077 »
« Reply #6 on: April 28, 2009, 08:50:42 pm »
Depends on crank pin dia (or if you want an extra 1mm stroke) but a quick look shows about 5 probable with a 24mm crank pin and another 5 with a 25mm crank pin. Ithink a RD/RZ 250/350 is the rod for the 175.
« Reply #7 on: April 28, 2009, 09:13:40 pm »
is there a direct equivalent for the ProX 03.6642 for the '93-'97 Skidoo 599 triple in Hot Rods brand?
the rod that works in PE175 is the TS185 rod. use Pro X 03-3018
what are rod brands are there?
« Last Edit: April 28, 2009, 09:31:42 pm by LWC3077 »
Offline BAHNZY
« Reply #8 on: April 28, 2009, 10:53:56 pm »
When i built the motor, we did indeed use a ProX 03.6642 rod kit however we diddn't use the pin that came with the rod kit. As mick had previously advised, we also ordered an extra (generic) 06.2458 big end pin. There was an issue in the build up of the crank and it had to do with the thrust washers as the ProX rod was wider then the Suzuki unit. I will check with the "Guru" who built the engine and find out what he used for thrust washers.
If you are starting to think that this is not worth the effort, then consider that all of this, including the labor, was cheaper than a Suzuki rod kit, that wasnt avalible anyway.
FYI, the small end pin, bearing & piston were all off the shelf Woosner oversize PE units as per the book. I went for the Woosner as it was the only piston that came with the teflon coating standard.
Rod (BAHNZY) Bahn
Re: PE/RM250 Con Rod
« Reply #9 on: April 28, 2009, 11:06:59 pm »
never said it wasnt good value, i just want to expore/compare options as i can get different brands cheaper than others and if a Hot Rod or other brand is available then maybe it might be better. I would also like to compare rod weights
i actually have a complete NOS OEM rod kit but thats for the all orginal motor. The aftermarket one is for the trick modifed motor.
Yeah the Wossners are good. Thats what im getting.
« Last Edit: April 28, 2009, 11:10:13 pm by LWC3077 »
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #10 on: April 29, 2009, 07:22:33 am »
Depends on crank pin dia (or if you want an extra 1mm stroke) but a quick look shows about 5 probable with a 24mm crank pin and another 5 with a 25mm crank pin. I think a RD/RZ 250/350 is the rod for the 175.
which reminds me... I have a PE175 looking for an RD rod, I believe  ;D
