Author Topic: IT175G airbox/filter  (Read 18585 times)
Offline Graeme M
  • Administrator
  • Canberra, Australia
Re: IT175G airbox/filter
« Reply #15 on: January 03, 2015, 06:10:36 pm »
Thanks Woody, mine is 15cm too. Here's the twin Air application chart, look for 152400.
http://www.twinair.com/worldwide/images/stories/Twin_Air_Application_Guide.pdf
But don't buy one, it won't fit...
Digga, Woody, what do you make of this?
NU-2245ST from Uni Australia is the green and yellow one for the IT175G that I am using now.
NU-2245ST from Uni Filter US is a black and red one for the YZ/IT 250/465 (and IT175G/YZ125G?)
NU-2247ST from Uni Filter US is a black and red one for the IT175G/YZ125G
All very strange, I am now thinking there ARE two possible cage/filter combos for the 175G.
Here's the 2245ST green/gold one:
http://www.uniflow.com.au/contents/en-us/d78.html#p1107
2245ST black/red:
http://www.ebay.com.au/itm/Uni-Air-Filter-NU-2245ST-/390532013032?pt=Motorcycles_Parts_Accessories&hash=item5aed859be8
2247ST black/red:
http://www.ebay.com.au/itm/Uni-Air-Filter-Yamaha-IT175-1980-1981-YZ125-/291089268066?pt=Motorcycles_Parts_Accessories&hash=item43c645bd62
« Last Edit: January 03, 2015, 06:20:49 pm by Graeme M »
Offline Digga
« Reply #16 on: January 03, 2015, 06:13:24 pm »
Guys
I got mine (2247 ST) via DC Plastics & they are still on their website @ USD$26.95
http://www.dcvmx.com/xcart/product.php?productid=17410&cat=331&page=3
1977 Yamaha YZ250D, 1977 Yamaha YZ400D, 1980 Yamaha YZ125G
Offline Digga
« Reply #17 on: January 03, 2015, 06:15:22 pm »
BTW, I also use the yellow one (2245 ST) without the second layer & it fits OK then  ;)
Offline Graeme M
  • Administrator
« Reply #18 on: January 03, 2015, 06:25:08 pm »
Yes, I've now bought a 2247ST so fingers crossed it's a goer. Uni US shows the 2245 for the 250/465 and the 2247 for the 125/175.  I think Twin Air are mistaken in their application, so my advice is don't buy one for the 125/175...
http://www.unifilter.com/online-catalog/
« Reply #19 on: January 03, 2015, 06:31:49 pm »
Re: the hole.
YZ125G (and presumably H) filters are held in by the cage, via two wingnuts on the OUTSIDE of the airbox (on the carby side). So they're not meant to have the conventional single hole.
Offline Woody
  • Heaven #70
« Reply #20 on: January 03, 2015, 07:43:16 pm »
Re: the hole.
Nath, that's the 250/465's,  the 125's definitely have the single bolt mount at the top of the filter inside the airbox. Macca, the 2247ST will fit.
http://www.partzilla.com/parts/search/Yamaha/Motorcycle/1980/YZ125G/AIR+CLEANER+YZ125G/parts.html
http://www.partzilla.com/parts/search/Yamaha/Motorcycle/1980/YZ250G/INTAKE+YZ250G/parts.html
WANTED
1988/89 125 - CR KX YZ
IT200 stuff
CR250RD parts
Offline Digga
« Reply #21 on: January 03, 2015, 08:16:49 pm »
Correct Woody
Someone had wrongly fitted a 250/465 into my 125G & it was a dog's breakfast  ::)
Now that I have got a 175G box in there with the right cage etc, all is good  ;D ;D ;D
Couldnt find an NOS or 2nd hand 125G one anywhere, so the 175G was a winner (exactly the same)
« Reply #22 on: January 03, 2015, 10:07:19 pm »
I had two 125Gs with the two bolt/250 style air filter set ups in them.
Maybe a mid-year change?
This could explain why the filters are wrong.
Offline Woody
  • Heaven #70
« Reply #23 on: January 03, 2015, 11:12:06 pm »
Those bikes must have been modded by the prior owners to take the 250 cages. The same airbox carried through to the H roller that I had.
http://www.partzilla.com/parts/search/Yamaha/Motorcycle/1981/YZ125H/INTAKE/parts.html
WANTED
IT200 stuff
CR250RD parts
Offline Graeme M
  • Administrator
« Reply #24 on: January 04, 2015, 07:31:48 am »
Mind you Woody, going by that diagram the H airbox must have been slightly different - check part #18. That suggests the cage retaining strap inside was made to be less difficult to manoeuvre the cage over....
Offline Yamahaha
  • Melbourne Vic
« Reply #25 on: January 04, 2015, 09:59:47 am »
Yeah that shows the thread in the plastic disc bit is a bolt, mine all have a pressed in brass thread and the bolt sticks out off the retaining hoop in the air box
YZ 250 modern, YZ 125G, YZ 125E, IT 400D, IT 175G x 2, YZ 400F CR250re,  2012 yz450fse Service Honda CR500AF.   Viper #73
Offline Graeme M
  • Administrator
« Reply #26 on: January 04, 2015, 10:17:45 am »
Yep.
Definitely some weird stuff with those G/H airboxes! Well, let's see how this Uni filter I bought goes. I'll try to return the Twin Air filter and point them at this thread if I get any issues, but the seller would be right to say that Twin Air have marked the item as IT175G/H so how would he know any different?
Offline rodc
« Reply #27 on: January 14, 2015, 08:09:06 pm »
I took a look at several G and H  air boxes, both for YZ125s and IT175s, that I have and it confirms that there are two different lock nut styles. G's thread onto a fixed bolt coming out of the box bracket and H's have a threaded arrangement as per #18 above.
In either case, the cage and hence the air filter are the same.
Rod
