Author Topic: flat slide vs round  (Read 14349 times)
flat slide vs round
« on: December 03, 2014, 06:14:20 pm »
Ive only ever used round slide but what is the best out of flatslide and round, and why? as I am just about to use a flatslide TM38 for the 1st time
Re: flat slide vs round
« Reply #1 on: December 03, 2014, 08:12:27 pm »
The early Mikuni flatslides are (in my experience) harder to tune/fussier than a Mikuni roundslide and don't seem to offer a worthwhile improvement in performance or throttle response.
For my money, there's only two carbs that should go onto 2T dirt bikes: the Mikuni VM and the Keihin PWK. I will entertain the Lectron option if you're prepared to get your head around them.
« Reply #2 on: December 03, 2014, 08:18:58 pm »
 I will second Nathan , Shelpi the VM is the best option for simplicity by three lengths of the main straight.
 I do have some knowledge of tuning Lectrons (and parts) DON'T Bother.......
« Reply #3 on: December 03, 2014, 08:19:03 pm »
There is not much in it, nothing wrong with the TM flat slide especialy with a powerjet
« Reply #4 on: December 03, 2014, 08:24:15 pm »
Damnation Lozza ... I have had SFA to do with them :P ;)
Offline sa63
« Reply #5 on: December 03, 2014, 08:25:48 pm »
What about the keihin pe
Seems very similar to a VM?
« Reply #6 on: December 03, 2014, 08:39:52 pm »
Too hard to get jets for.
« Reply #7 on: December 03, 2014, 09:51:38 pm »
lot of punters in the US on old huskys having good results with the Lectrons.
« Reply #8 on: December 03, 2014, 10:53:28 pm »
There's too much to write on this subject in a post here.  There are many things to consider, sure a flat-slide will give a stronger pulse over the needle jet at part throttle but if you want more power at 'part throttle' ..... just open the throttle more.
I like the idea of a VM round slide Mikuni but with a 'slide optimiser' filling the void under the slide giving a stronger pulse at part throttle, plus a more streamlined venturi at full throttle.
I disliked the early Mikuni flatslide I had one on my RM250Z, the vacuum at part throttle use to make the throttle valve hang-up, I think the tiny return spring wasn't powerful enough to push the light plastic slide home; had the same problem with the first model GSXR750's.  Loved the wheels on the FCR41 slides on my ZXR750 :-)
Once I get the jetting fine tuned on my Keihin PE38 round slide on my CR500, I'll be happy.  Liking the VM38 on the KX400.
« Last Edit: December 03, 2014, 10:55:37 pm by John Orchard »
« Reply #9 on: December 04, 2014, 08:03:41 am »
Like Nathan says, Lectrons are cool & good but a head fu*k, as are EI & Blue Magnum. I've used a few Mikuni TMX's and although people say they are harder to jet than a PWK, I've not found that to be the case. A VM round slide with a power jet works nice too. Bings are unreal till they get worn, even though you have to douse your engine with fuel to start them.
Offline grouty
« Reply #10 on: December 04, 2014, 09:52:10 am »
I have used the good old round slide VM's for years. They were always ok. Just ok, not perfect.
I was having issues with the Husky 390 after I fitted a set of Boysen reeds. Never could get the jetting just right. So I bit the bullet and bought a Lectron. The transformation was incredible. So simple to understand, set up and use. I am now kicking myself for not using one years ago. They are way better than back in the 70's and 80's. The power jet also helps.
I will never go back to a Mikuni now.
The Lectron is very simple to get your head around. Just expensive. But then again, the best always is.
Am I biased now ............. :-)
Yep.
Thumpers Rule !
« Reply #11 on: December 04, 2014, 10:27:02 am »
thanks eveyone, well thats plain and simple, stay with what I know best ! VM Mikuni, but seem that I have gone to the trouble of doing the initial set up with the TM I will run it 1st then I can do a comparison ;) the lesson here is the one I should already know, do the home work first and dont follow like a sheep :-[
« Last Edit: December 04, 2014, 10:35:27 am by shelpi »
« Reply #12 on: December 04, 2014, 12:40:19 pm »
I just got off the phone to Ian Williams (Tuneing) had a chat and he seems to think both are fine :o
Any who asked how much for a New VM38 $175.00 was the answer, so in for a penny in for a pound ;)
« Reply #13 on: December 04, 2014, 05:31:11 pm »
everything runs a distant second to a Dellorto PHBE/PHSB/VHSB  ;)
Offline Momus
« Reply #14 on: December 04, 2014, 11:26:46 pm »
Quote from: Lozza
What would make you run one of the Dellortos in place of a Keihin PWK Airstriker on a big bore 2 stroke?
If you love it, lube it.
